Reflash?/
Discussion in 'General Subaru Discussion' started by KSAL, Sep 13, 2006.
  1. KSAL
    KSAL Well-Known Member
    Real quick question. Should i reflash my ecu before i go to the dealer for my 30K check up?? I have the AP. Thanks Later
  2. Steve-o
    why? If you are concerned just tell them not to reflash the ecu. I highly doubt they would anyways.
  3. Grgkng
    Grgkng New Member
    I think you should. You can flash it back later anyways right?
  4. AWDimprezaL
    i thought on stage 2 sti you HAVE to run the ap otherwise you get boost creep...just leave it, what dealer are you taking it to? if you are taking in to tonka make sure you have ben or brian work on it.
  5. KSAL
    taking it to morries BP
  6. Scuba Steve
    I would probably just leave it. If I recall correctly, the 30K is a basic inspection and lube/fluid change
  7. Chin
    Chin Well-Known Member
    Nope, no boost creep on mine.
  8. LVT
    LVT Well-Known Member
    it can be solved by porting the wastegate on the turbo.
