Removing Intake Silencer..little help here
Discussion in 'Modifications And Maintenance' started by ej20, Jun 29, 2007.
  1. ej20
    ej20 Well-Known Member
    Was trying to take out my intake silencer the other day but didn't got enought time so I didn't do it. The thing is I'm not so sure what to do since its my first time removing my fender. Well I guess I'm too lazy to find out by myself so I'm gonna ask first b4 I head back into taking it apart again. Got all screws from top and side of fender(and that was as far as I go only) so what's next to get the fender off?
  2. piddster
    Boostonia
    You should be able to do it by just removing part of the inner fender liner. If you remove the fender, you'll have to spend some time making it fit properly with the hood, door, bumper cover, and what not.
  3. SUCKERPUNCH
    SUCKERPUNCH New Member
    The blue bird can sing, but the crow's got the sou
    I did this last spring, I had my dad help me its a lot easier with another set of hands. You don't need to take the fender off. I loosened the inner fender like piddster said, then I removed the thin plastic lining under the front bumper and pulled it out from the bottom. That plastic should flex enough to pull the silencer out. It was still a pain to get out, but it will come out.
  4. pksublime
    pksublime Well-Known Member
    anyone done this on an '06? is it much different? (guessing it's not)
  5. Bullwinkle
    Saint Paul
    No, although my silencer was white. I took of the front passenger side wheel, as it made it easier. Took all of 5 minutes.
  6. TSTRBOY2004
    it literally is like 2 10mm nuts inside the fender.. or one inthe fender one inside the engine bay... then pop a couple of clips on the inner fender guard, and pull the silencer out the bottom of the car... takes maybe 10 mins tops
  7. STi hog
    STi hog Well-Known Member
    Minnetonka
    i did this to my 06 and had no problems, took only a couple of mins to do.
  8. pksublime
    cool thanx guys
  9. Aegis
    Female
    サイレントヒル
    oh right, i still have to do this too ... :roll: ;)
  10. ej20
    ok, did it and its only two bolts. Easy and simple. Here's a pic of the silencer removed if some of you guys havn't seen it. 02 wrx
  11. esperunit
    esperunit Well-Known Member
    Paris, 7eme Arrt.
    hmmm 06 is shaped differently and is white. I cant remember where i put mine so i cant take a pic
  12. ej20
    Should I use this? It doesn't have a hole on the bottom of the filter yet for water from the Stock air tube from the front grill. I dont think I need it but should I?
  13. gran0393
    gran0393 Well-Known Member
    Lost in the Burbs/Bugeye #005(RIP)
    i just left it completely out (psst...you don't need an air filter there theres one in the airbox)
  14. ej20
    haha, it looks cool...but yea I dont think I want it.
  15. mlgez
    mlgez Well-Known Member
    Around
    If you cut it off a little higher and close it up you have a GP-Moto elbow. There is someone on here that did that instead of spending $45 on the elbow.
