removing paint from rims
Discussion in 'Modifications And Maintenance' started by MPLSREX, Mar 22, 2006.
  1. MPLSREX
    MPLSREX Well-Known Member
    I bought some og WRX rims and the previous owner painted the tops of them. Not a problem since I plan on painting them black, but I was wondering the best and easiest way to remove the paint? Anybody have a sandblaster?
    Here's a pic.
  2. Squiggly
    Squiggly Squiggly
    get something called aircraft paint remover.. i think thats it.. u can get it at walmart or checker for like 7 bux.. its basically a really strong paint thinner
  3. subaru4
    subaru4 New Member
    ^ make sure that u get a good paint brush cuz if you dont then when u start to put that stuff on the rims it will eat the brush
  4. Squiggly
    Squiggly Squiggly
    i just used a rubber glove and rubbed it on by hand
  5. MPLSREX
    ^^Like wire brush? I thought I would apply it and then have to scrub the old paint off.
  6. subaru4
    subaru4 New Member
    readymix should know what i am talking about
  7. Squiggly
    Squiggly Squiggly
    just rub the stuff on.. let it soak in and then most of it should run off under water.. there might be a little left over , if so let some more settle then just get a paint scraper and scrape it off
  8. MPLSREX
    THANKS! I'm going to go get some today.
  9. StatGSR
    StatGSR Well-Known Member
    its Aircraft Remover. it comes in spray cans as well. but yea spray it off then scrape whatever is left...
  10. Shane86
    Shane86 Well-Known Member
    be warnned... if your going for bare metal, it will take a LONG time... even with the aircraft stripper.
    i would just give it a single dose to get anything loose off, and then take a scuff pad to it.
    follow it up with a good coat of self etching primer and then a coat of high fill primer and that **** should last a long time.
  11. MPLSREX
    Yeah, i just want to get that layer of paint off, and then I'll scuff the clearcoat off, then prime, paint, and clearcoat a bunch.
    All I need is a place to do it. I don't feel like doing it in my driveway and spraying the $%# down to go into the alley.
  12. illegal2.2
    illegal2.2 Well-Known Member
    any updates?
