replacing brake pads
Discussion in 'Modifications And Maintenance' started by carl, Aug 11, 2006.
  1. carl
    I'm going to do the pads on my STi pretty soon and was just wondering if there's anything i should know before starting - or is it just like any other car? (i know my 240's have goofy rear calipers - have to twist the piston back in instead of just pushing. just curious if there is anything weird like that. i'm a subaru noob :( ).
  2. MCJT
    MCJT Well-Known Member
  3. Nuke
    i was wondering if this applied to the 06 wrx's also
    looks the same
  4. silver03
    Twisting the rear piston in is pretty much a standard affair on almost any car in the rears (e-brake related). Its very straight forward on these cars.
  5. piddster
    Rear calipers on single piston subaru's don't require any twisting. I use a large channel-lock pliers to compress the piston, but others use C-clamps. I can't imagine the 2 pots on the STi being much different. My RB 4-pots in front don't need any twisting. Just be carefull with the powdercoating...
  6. JeWrX
    JeWrX Well-Known Member
    I used a c clamp to compress my pistons when changing my pads, the dirty part is i would compress one and the other would pop up so i had to wedge a piece of wood under there to get em both at once.
  7. carl
    thanks for the tips guys
