Reving engine
Discussion in 'Modifications And Maintenance' started by blake, Jan 21, 2008.
  1. blake
    blake Well-Known Member
    I have been having an issue with my 02 WRX this last weekend. Whenever I am accelerating, every time I push in the clutch to change gears, the engine revs up to a 1000 RPMs, holds it for a split second and either goes to idle (with the clutch still pushed in) or holds the higher rev for a split second more if I disengage the clutch after shifting into the next gear.
    I have no idea what is causing the issue, but it is extremely infuriating and I am hoping it is not causing undo damage to the vehicle. Any info would be greatly helpful. Thanks.
  2. hella_sti
    hella_sti Well-Known Member
    idle air control valve gasket
  3. AWDimprezaL
    you mean idle air controll gasket needs to be changed, when you clean your idle air controll valve because its dirty :) :wavey:
  4. hella_sti
    either or, I think the gasket is cracked and the valve might be a bit dirty.:yumyum:
  5. AWDimprezaL
    :wiggle:
  6. Speedemon
    Speedemon Well-Known Member
    :wavey: good job guys
  7. piddster
    What is the best way to clean an IAC valve, btw. I've been putting it off for quite some time. I think thats why my idle is crap. 200k miles and no cleaning on this bad boy.
  8. Scuba Steve
    We used TB cleaner on Silver03's 2.2l with the same issue. replaced the gasket too. still does it though, but not as bad.
  9. FuJi K
    isn't the Subaru WRX known for this??? The transition between open/close loop?? HOW MANY milli-SECONDS before switch over??
  10. piddster
    TB cleaner? As in throttle body cleaner? I was thinking I'd spray the hell out if it with carb cleaner. I do get a fair amount of exhaust reversion with these cams.
  11. AWDimprezaL
    for the older you dont have to take the iac off, just spray down that hose, i use TB cleaner, A **** TON OF IT while running (you gotta keep it running with your hand)
  12. blake
    Hey thanks for the info guys. I will have to give it a try when I get back from work.
  13. tux121
    tux121 Well-Known Member
    I thought you couldn't do this to pressurized manifolds?
  14. AWDimprezaL
    of course you can
  15. Justin
    Justin Well-Known Member
    yes, i've seen many threads about it on nasioc and i dont ever remember it being the iac gasket
  16. AWDimprezaL
    clean your iac and buy a new gasket (we have them in stock)
  17. blake
    Well I finally cleaned my iac today. It was much much easier than I expected. I used a impact screwdriver (5 bucks at Menards), a ton of wd40, and put a new gasket and screws on. So far, it seems to work alright. No leaks that I could tell.
