rims fitting?
Discussion in 'General Subaru Discussion' started by philly_mane, Apr 8, 2009.
  1. philly_mane
    philly_mane Well-Known Member
  2. Moleness
    At work or in the garage
    You need to know the offset...
  3. philly_mane
    he said +35
  4. carl
    we gotta gooooo
    18x8 +35 on a wagon is not going to be easy. will require fender mods
  5. philly_mane
    so that means an offset between +40 to +48 would be fine?
  6. readymix
    Eloh, El
    It also depends on the tire size you run, but typically you'll want to run between 40-52 depending on wheel width.
  7. philly_mane
    ok what would be the best tire size if i get 17's?
  8. Vector
    Vector Rally Organizer
    It depends on the rim width.
  9. philly_mane
  10. Vector
    215/45R17 no problems. Wider might require rolling the fenders.
    I can't really see wanting to go with wider than 215 on a wagon unless you're a die-hard autocrosser or you're making some sick power. Good tires in that size will stick like nobody's business.
  11. philly_mane
    thanks much for the info!
  12. bhiku
    bhiku Well-Known Member
    Aversa, Italy (formerly BRF, WI)
    http://forums.nasioc.com/forums/showthread.php?t=450557
    First post has some good fitting info. Always look at more than one source for your info, but it's a good starting place to get you in the ballpark. The guys posting above are gold, and will keep you straight, the link gives you background info.
  13. 9blackmax6
    5 hours north of you
    if you didnt want to roll your fenders, depending on suspension mods i would run 225 45 17 unless the wheels you are buying have a super low offset >30 i think you'll be ok.
    im running that size on my legacy with .5* camber and i dont rub at all. im also lowered about 1.5-2 inches.
  14. Vector
    225/45R17 will most likely fit fine, but they are going to be a bit larger in diameter than stock, which will lower acceleration (probably not noticeably), increase gas mileage (again, probably not noticeably), and cost more (probably noticeably :) ). I can personally vouch for the 215/45R17 on a 2002 WRX wagon. I had Michelin Pilot Sport PS2 tires on that thing and it stuck like glue.
    If you're going for the really wide look, even a 225 probably isn't going to look a lot different than the stock 205. I forget what wheels & tires Bullwinkle has on his car, but they're friggin' huge. But that's a sedan, and I'm pretty sure his fenders are rolled.
  15. Shibbs
    Please stop giving advice on things you don't KNOW about.
    I'm running 225/45/17 on a +35 offset on my 07 sedan. IT RUBS. No my fenders are not rolled, but there's NO WAY a +35 would fit a wagon. +40 would clear my sedan, but that is all I can say.
    If the guy is nice enough, see if he'll let you test-fit a wheel. That's really the only way to know without seeing the offset. Ask for detailed pictures of the back of the wheels. The offset will read like: ETXX where XX is the offset. ex: ET44 will be a 44 offset.
  16. 9blackmax6
    that was one number that flew off the top of my head i was merely giving a rough example of a low offset sheesh :rolleyes:. anything in the 30's is aggressive if you want to run a wider tire with it. even the low 40's would be considered fairly aggressive.
    EDIT
    if your chosen wheels do rub a little bit, there is always a big bulky rubber fender liner you can take off to give you an extra couple mm of width clearance for your tires.
