Rotors install...
Discussion in 'Modifications And Maintenance' started by John16V, May 18, 2004.
  1. John16V
    John16V Well-Known Member
    My car vibrate during hard braking...and I think is time to replace front and rear rotors....so is it a easy job?? or very difficult?? Tips??? advice??
    Anybody wants to help????
    J
  2. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    The rotor should pop right off after you remove the brake caliper. You changed brake pads before, right? :)
  3. Substeroo
    Substeroo Well-Known Member
    Pretty easy. Unless there's alot of rust on those caliper bolts. I did mine in less than an hour.
    1. Parking brake engaged, jack the wheel up.
    2. Take off wheel.
    3. Behind the caliper are two (12mm I think) bolts that hold the caliper on, They are kind of long. Take those off.
    4. Take caliper off and let it rest on something, DON'T LET IT HANG BY THE BRAKE LINE.
    5. Take old rotor off, put new rotor on and check brake pads for wear.
    6. Put caliper back on.
    7. Put wheel back on.
    8. Put car back down.
    9. Pump brakes until firm again.
    This was an abridged version, and you may need a C-clamp to compress the caliper.
    Someone else will probably add more.
  4. John16V
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">The rotor should pop right off after you remove the brake caliper. You changed brake pads before, right? <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
    what's a brake pads?! hehe....nope I didn't
  5. bikerboy
    on the water looking for the sandbox
    <font size="4"><font color="red">jack stands!</font id="red"></font id="size4">
  6. RallyNavvie
    RallyNavvie Well-Known Member
    Dallas
    You missed out on the rotor buy! Those would have lasted you a good long while. I missed out on getting frozen rear rotors. D'oh!
    I'm lucky, I have a climate-controlled shop to work in with in-ground hydraulic lifts. I'm putting my new brakes in Thursday. Did you know STi made a 2-pot rear brake kit for the GCs? Sweetness :D
  7. subi_2.5rs
    subi_2.5rs New Member
    ghettofornia
    will john....come to my place and i can help you out.....
  8. Chux
    Independence, MN
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by bikerboy
    That's a mistake you don't make twice!
  9. John16V
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">[Did you know STi made a 2-pot rear brake kit for the GCs? Sweetness /quote]
    Really?? how much???????? :D
