rs modding?
Discussion in 'Modifications And Maintenance' started by LilRed, Feb 12, 2006.
  1. LilRed
    LilRed Well-Known Member
    i know there is all these ways to mod you wrx and sti. i was just wondering if people would give some inputs on modding a rs. i know it gets expensive when you want major power but any little bit of power would help. Show the ways and steps.
    thanks for all info's.
  2. kickin_81
    kickin_81 Well-Known Member
    There's too much to know. :p Where do you want to start? Engine? Suspension? Exterior/Interior? Drivetrain?
  3. Squiggly
    Squiggly Squiggly
    he said "power" so im gonna say exterior/interior
  4. tbone
    tbone Well-Known Member
    Motor Sw4p!!!
  5. AWDimprezaL
    headers and a lightweight pulley will help you out a bit...but a swap would yeild more hp for the money
  6. snbrd4evr
    snbrd4evr Well-Known Member
    Lightweight flywheel
    Exedy Organic Clutch
    Lightweight Pullies
    equal length headers
    catless exhaust (2.25")
    cold air intake
    tuned Perfect Power
    Now you'd be set, and nearly as quick as a wrx... to 60 :)
    although it'd cost almost as much as a swap :cry:
  7. LilRed
    also if you guys have an idea of the price ranges of each of the parts and an idea of the gains( either hp or time off the 1/4) would be appreciated too. i'm just trying to help out myself and any other rs owners on the limits of the rs and prices and then maybe compare it to a swap.
    thanks guys
  8. AWDimprezaL
    the best 0-60 part i would hafta say is the flywheel, when i installed mine, it was insane compared to stock, but you'll lose top end, soobies dont really have top end anyways :evil:
  9. readymix
    engine swap. EJ20's can be found for cheap. A new STI shortblock isn't very expensive either, but you'd be better off hitting up one of those 800 dollar WRX engines on eBay. All you'd need would be a wiring harness and an ECU after that.
  10. powerlabs
    powerlabs New Member
    Here is how you mod an RS for power:
  11. kickin_81
    ^^doesn't it scare the crap out of the alternator when the alarm goes off by the way you hooked up your alarm??? Hehehe, I love your engine bay, dud3!
  12. 02blubru
    ^^^ROFL @ scared alternator
  13. kickin_81
    If you want, here's a baseline you could use and try to beat its price. $4000!!! to get mid-14's and staying normally aspirated. Cobb Tuning!
    http://cobbtuning.com/impreza/powerpackage3.html#streetcam
    Rallitek header: Staying N/A? This header will bolt onto your Brullen catback (you have a brullen, right?) http://www.rallitek.com/products.asp?ID=70&PP=&HB=&ACC=&SP=Y
    AVO turbo kit: Rallitek again. The best price on an AVO turbo kit ever! I assume it is reliable, but I'm not totally sure. There are many guys with this turbo kit on www.rs25.com that are happy with their empty wallet. http://www.rallitek.com/products.asp?ID=600&PP=Y
    Z1 Performance: Exedy SPORT clutch. This is a different place with a different price as what I've told you from before, Paul. This clutch holds about 29% more torque... which should be enough to handle AVO's turbo kit. http://www.z1auto.com/prodmore.asp?model=legacy&cat=driveline&prodid=62
  14. AWDimprezaL
    if you were gonna go turbo kit, ide make sure you had headgaskets done, with the updated gasket, yours is the dohc headgasket eater :oops:
  15. esperunit
    esperunit Well-Known Member
    you can use a 2006 2.5i intake manifold, Techworks Shortblock package w cams (stage 1 or 2) and a techworks equal length header and you will be faster than a WRX. All of this is going to run you about as much as an engine swap costs however, but the results are pretty good.
    To get to STi power on this setup you'd need to run race gas an an insane compression ratio, but it has been done. TWE has a car that's build rivals an STi swap that is faster on the 2.5RS motor, but I wouldnt consider it streetable because the compression ratio forces it to use nothing but 100+ octane gas.
  16. Parrot
    Parrot Well-Known Member
    i have an 06 2.5i - is there a chip i can put in to add a few more hp. i've heard it done, more with audi's but i think the 2.5i comes stock with 170 hp or something - what could i do to get it over 200? flywheel?
  17. DISCOPOPE
    DISCOPOPE Well-Known Member
    you wont see alot of 'chips' for the subarus.
    you will be looking at getting a reflash/protune.
    untill then look into freeing up exhaust.
  18. Dynapar
    if you want big power out of the RS you will be best off with a swap. since w/ the swap there is alot of aftermqarket parts and mods you can do. while staying Na youa re fairly limited.
    possible NA mods:
    perfect power
    headers (equal lenght has been rumored to remove boxer ruble)
    catback
    intake
    short shifter
    flywheel
    clutch
    high comp. pistons
    titanium valve train w/ springs
    cams
    intake manifold
    port and polish.
    most of these can be done w/ or w/o a swap. and the dissadvantag is that w/ higher compresiion you will no get close to the potention power a swap would yield and still be streetable.
    but if you are crazy and want NA check out the TWE (tech works engineering) 230whp NA RS.
  19. LVT
    LVT Well-Known Member
    well if i was to mod my RS for power. here's the route i'd go if i dont go turbo.
    cobb CAI - 100-300$ depending on condition
    cobb equal length headers with cat delete- 400-900$ depending on condition
    custom 2.5in straight pipe with 3.5in magnaflow tip- 35-200$
    twe or cobb street cams- 300-500$
    exedy organic clutch and lightweight flywheel- 600-700$
    perfect power 300-500$
    that's about all the major mods i can think of before doing internal work or swap
  20. Dynapar
    thats a good setup. i would personally go with some non equal lenght headers. maybe borla or something else. and possibly a port and polish. if no cams i might say go w/ 2.25" exhuast i have heard the high back pressure give better numbers on RSs. unsure though.
  21. AWDimprezaL
    cobb's headers take away the boxer sound, as do any equal length system, but do make around 3 more hp then borla, ide trade the hp for the sound, you cant feel 3 hp anyways
  22. rskm1
    rskm1 Well-Known Member
    <-- my vinyl graphics add +15HP... Each side. :lol:
    Or if you want some serious bang for the buck (until you break something, of course)...
    We now return you to our regularly scheduled serious suggestions.
  23. kickin_81
    Sorry, Erik. I have to partly disagree with you. Just tested last year, the borla header was the bottle neck for a heavily modified N/A RS. The RS ran a 14.5 or something on teh 1/4 and the owner didn't know what was wrong. When he changed the headers to equal length, the car was tuned again and ran somewhere in the mid 13's. I understand this was a heavily modified car, but it isn't a 3 HP difference going from a Borla header to an equal length header. Cobb's EL header prooved 13 WHP on a close to stock RS. But you should understand that Cobb also has a high-flowing cat in place of the 2 OEM cats. There you have it. :p
  24. Dynapar
    i would prefer the sound over the hp also. the borlas maybe the bottle neck but who said you need to use borla. if you can get Fuji brand!!!!! his RULE!
  25. gc8
    gc8 Well-Known Member
    is there anywhere in MN that can do WRX swaps? Any suby knowledgable shops?
  26. AWDimprezaL
    pm bikerboy, he just did a ver8 sti swap
  27. gc8
    any idea of how much a wrx swap would run...ive heard $4000.
  28. Squiggly
    Squiggly Squiggly
    equal length headers dont sound bad do they?
  29. LVT
    i personally like it, i had them on my Silver RS and the sound was awesome especially at wOt...the car still rumbles downlow...the tone only changes when you're at wOt.
    actually the power difference between the borla and equal length header is a BIG amount. A friend of mine has borla headers with catback in his RS and his wasn't as fast as my silver one at all. I can instantly walk him.
  30. Dynapar
    the equal lenghts dont neccesarily sound bad, they just sound differnet. since the echasut from each head has totravel teh same lenght there is no interference from the gases. w/ the non equal lengths, one side od the exuast has to travel a greater distance before the two meet up again, so when the meet up they interfer w/ each other and make good sounds.
  31. tbone
    Who's got an equal lenght headers from this board?
  32. AWDimprezaL
    stock are equal, but petes old rs had crazy cobb headers, it sounded like a pissed off inline somthing or other, no rumble to it at all though
  33. Dynapar
    are stocks equal? i could have sworn that the drivers side has to travel farther before it meets up with the passenger side.
  34. gc8
    stocks are NOT equal. They are equal on the new 06 RS's though...
    personally i plan on getting equal length cus i would take performance over sound.
  35. LilRed
    so does anyone know or even give a ball park for price and any other shops?
  36. Dynapar
  37. LVT
    did you hear it when i put that 2.5 straigth pipe on it? it rumbles like a subaru without borla headers til i went wot.
  38. AWDimprezaL
    ^^^ true, at idle...but as soon as you even thought about touching the gas we were covering our ears :D
  39. asiandude
    asiandude Well-Known Member
    agree with eric on this one. i would go with the borla header too.
