rust problem to say the least!
Discussion in 'General Subaru Discussion' started by Scott, Oct 11, 2014.
  1. Scott
    Scott Well-Known Member
    I was looking for a different problem and found this bigger one. This is the front control arm and front frame rail. I know the control arm can be fixed, but is the frame able to be easy enough?
  2. phi11
    yeah
  3. Sjogun
    Sjogun Active Member
    Front sub frame can and should be replaced. Have seen a lot of them being replaced in conjunction with the control arm recall.
    spudd likes this.
  4. Scott
    I just went to the dealer in maple wood. Funny that they even had the parts in stock. Now I am in search for experienced parts.
  5. spudd
    spudd Well-Known Member
    What year and model? There is a recall and subaru should replace at no charge
  6. Scott
    Its an 02wrx. It was brought in for that recall. At that time it was said to pass the test. They did apply the rust proofing stuff. So the dealer said I have to speak to the corporate office to see if it will now fall under the recall.
  7. spudd
    Ya I would say definitely do that
  8. Scott
    Yes and Subaru said that due to it passing the recall test there is nothing else they can do. Other than repair it at my cost at a Subaru dealer of my choice,at my expense. The one guy I talked haven seen pictures said that he wouldn't feel safe driving it till fixed.
    So LCA were ordered now looking at the sub frame options.
  9. EricS
    EricS Nooberator
    Hmm that's sucky. How long ago was the recall service done? Kinda fishy to me that it would have progressed so much in what, a year or two? I'm no tech but it seems to me that if they did the test correctly, and did even a little bit of extra poking around with a screwdriver, they could have seen this coming?
  10. Scott
    The test was done 9/28/11. So now I am out of pocket for the repair. I asked to prorate, compromise on parts anything. And was giggled at and was told it is a 2002. Wow.
  11. Sjogun
  12. EricS
    EricS Nooberator
    Good to know... I can see their point I guess, that three years on is enough time that they would probably see it as normal progression.
  13. Scott
    I am by no means a expert on rust, but I would like to think that looking at the size of the damaged sections. That this rust has been going on for a little while. And with it being a known problem that SoA would not be quick to brush the under the rug. Why no follow up to see progression of the rust. Now for the guys that have an 07 in 7 years are you Sol because your car based a test when you're car was 3+- years old? My point is my car is well taken for not a rusted POS. This is an existing problem that Subaru could be a lill bit more helpful on. I am not saying free. Because I am looking at this as a step to upgrade anyway. Like the saying says if it ain't broke don't fix it... Well mine is broke so I say upgrade. Parts to come soon.
  14. Sjogun
    Don't get me wrong, I agree with you...If you have a good service history at a dealer, it might be worth a try to see if you qualify for a one time good will repair.
  15. spudd
    This suprises me, subaru is very good about helping people when they call. Im suprised they arent helping you? Who did you talk to??
