Sale Time: Need $$ and Space for new projects. Car Parts.
Discussion in 'For Sale : Car Parts' started by Dynapar, Sep 5, 2012.
  1. Dynapar
    Time to make make room in the storage unit for a new project. I have lots of stuff to sell, and this thread will be updated frequently until it is all gone.
    **Pictures to come later**
    EJ205 Short Block: $300
    ~70K miles on it. Ran great when I pulled it out of my car about 1.5yrs ago. It was smoking a bit when I pulled it out (could use a new set of rings and would be back in it for along time!)
    EJ205 Heads: $100
    Will come with complete set of buckets & shims (will not be the right shims). The front cam cap was damaged and is unusable. Will come with a complete set of cam caps and stock cams, but will need to be line honed before they can be assembled/used. Also the front drivers cam cap mounting hole has been helacoiled and should be re-tapped.
    EJ22E Long Block: $75
    196K Miles. Definitely needs new piston rings (smoked alot when I pulled it out) Otherwise it ran great! Would be an excellent motor for a go-kart.... or an ITB setup :devil:
    2.5RS USDM Bumper Beam: $100
    Brand spankin' new, in the Subaru factory box.
    TD04 Turbo: $30
    Came from a 02/03WRX. Has some/minimal shaft play. high miles 150K+ Should still have plenty of life in it. Would make a good spare.
    2006 WRX Rear Hubs/Uprights: $100
    Complete setup left and right. Will come with good condition brake rotors and ebrake stuff, no brake calipers though.
    V3 STi Steering wheel: $20 SOLD
    Seen better days, but still is kind of neat. I do not have the center horn cap though.
    Primitive Racing Rear Diff Plate for R160: $60
    Used, but in good shape. Does not come with mounting hardware (left and right bolts and spacers). These should easily attainable at a hardware store. Fits 1993-2007 Impreza and others.
    2002 WRX TMIC: $50
    Many bent fins, comes with stock y-pipe but no TB coupler. TB side has been shortened by 1/4, should not affect fitment in any way shape or form.
    1 Falken Azenis RT615 225/45/17: Free
    Has 5-10% tread left. Kind of camber worn on the inside.
    Also for sale is a 99-01 impreza RS headlight brand new in the Subaru box with clear rock blocker on it, never installed in a car. $100
    More stuff to come as I find it, stay tuned.
  2. white bugeye rex
    white bugeye rex Active Member
    do u still have the TD04 turbo?
  3. caffeine
    caffeine Well-Known Member
    Could I get a pic of the diff plate?
  4. jing123
    jing123 Well-Known Member
    have pics of the steering wheel?
  5. white bugeye rex
    ill buy the turbo today if you still have it
  6. Dynapar
    I still have everything! Pictures will be uploaded by tomorrow night.
  7. Dynapar
    Pics:
    Falken Azenis
    EJ205 w/ the heads still on it. Heads will be removed prior to sale unless someones want to buy both and wants them together.
    TMIC : IMAG0965.jpg
    EJ22E:
    Diff plate: Has some dings/dents but still is 100% functional. Does not include rally mud/dirt/grass. IMG_8254.JPG IMG_8300.JPG
    Additional pictures coming soon.
  8. RexNEffect
    You're going to the rallyx Sunday, right, right?? ;) Bring steering wheel so I can take a look at it.
  9. Dynapar
    Yes I will be tat the rallyx. I will bring the wheel down.
  10. Dynapar
    Bump TTT. Steering wheel has been sold. TD04 Pending sale. Other stuff is still available. I am willing to entertain reasonable offers on these items.
  11. Swych
    Swych Well-Known Member
    im definately interested in the ej205 block and heads, since they have been sitting any idea on condition?
  12. Dynapar
    TD04 is still up for grabs.
    Condition on the EJ205 and heads are still really good. The short block sat for 4 years before I purchased it (was pulled due to a broken timing belt @~30k miles, and needing new valves and 2 replacement pistons. I dropped on a complete set of heads, and put in 2 stock pistons for cyl 1 &3.) and put it into my car, there were no issues at all with it sitting for so long. Like I mentioned this has been on my shelf for 2 years now; however everything should work fine. I would recommend replacing the valve cover gaskets just because the engine has been sitting with the valve covers off, and the existing gaskets are not to be found.If the heads come off, a re-hone and some new rings would ensure that this will last a lifetime.
    In regards to the heads, these will need a bit of attention. I do have all of the parts to make them complete and functional again. The main thing is the the driver side head will need to be line honed with the new front cam cap. Any engine or machine shop should be able to do this pretty easily. In addition the top bolt from the front cam cap has been helicoiled, and should either be re-helicoiled or drilled and tapped. (this bolt only tqs to 7.5 ft/lbs, so no real concerns over a helicoil failing). Beyond this it is pretty standard stuff, check valve lash and install new cam seals.
    Let me know if there are any specifics you would like more information on.
  13. 05wrxMike
    05wrxMike Member
    you still have the turbo
  14. Dynapar
    I still have the turbo. LMK if you want it, its just sitting in my back seat now.
  15. Dynapar
    Ttt. Willing to take $350 for the ej205 setup as it sits. Also still have the td04 for sale.
    I will add in a gauging interest for a used hta68. Hta68 is 2 years old, maybe 40k on it. This is currently installed in my car and working great. Looking to sell it, in order to upgrade. $900 obo.
  16. svxninja
    svxninja Well-Known Member
    Where are you located out of, I will take the td04
  17. subiewubi
    subiewubi Well-Known Member
    location?
  18. Deride
    All the valves good on the heads? I may be interested.
  19. Mike02cky
    Mike02cky Member
    Td04 still for sale? Mine might have died recently..
    BugIedIzzy likes this.
  20. Dynapar
    Located on the west side of the cities by St. Boni.
    All valves are still good on the heads. They ran fine when I was running the EJ205, except that the driver side top cam seal was leaking due to the helicoil that I mentioned in the original post.
    LawnMaster likes this.
  21. Dynapar
    Bump. Bumper beam is pending sale. Everything else is still available.
  22. Dynapar
    Price adjustment time:
    EJ205 now $250!
    EJ22E now: $50!
    WRX Rear hubs now: $75!
    TMIC now $30!
    This stuff needs to go go go!
  23. Dynapar
    TD04 is sold! Other stuff is still for grabs.
  24. MuffinPunch
    MuffinPunch Active Member
    Do you know if the WRX rear hubs, etc. fit on GC/GF chassis? If so, I want!
  25. John Yang
    John Yang Well-Known Member
    any pictures of the headlight?
