Sealent on turbo gaskets?
Discussion in 'Modifications And Maintenance' started by Threshld1, Apr 8, 2006.
  1. Threshld1
    Threshld1 Well-Known Member
    SLP
    Hey im swaping my legacy VF11 for a TD04 today. Ive heard suggestions on legacycentral of using Permatex Ultra Copper silicon gasket maker on the manifold to up pipe gasket. Im wondering if i should just use it on my uppipe to turbo and turbo to downpipe gaskets as some extra security. Anyone know any reasons why this wouldnt be a good idea?
    If so should i just put it on one side or both?
    Thanks
    Kent
  2. wall of tvs
    dream ftw
    I use Copper Cote on all of my exhaust gaskets, and have had success with that.
    There is a line of thought, however, that you don't want to put anything like that pre-turbo. It's up to you to decide, I guess.
    The main thing that will prevent leaks at the manifold/uppipe joint is following the proper torquing procedure and using a torque wrench to insure even pressure across the flange.
