I am rebuilding a 98 Subaru impreza 2.2 wagon L and have a complete set of shocks, and an overhauled motor with no miles on it $1000. New maf air flow sensor $250 and 4 brand new tires $400 and they were bought just before i ynaked the motor out. The body has 140,000 miles on it. I bought this car under the impression that it was a sound car with a running motor that turned out not to be the case. I have fix so much with new parts that all that needs to be fixed is the foam i put in the hole to prevent water from coming jn the wheel wells i have personally check the crank and measured it to be within 1 ten thousandth of spec below on to pins and within spec on the jurnols the oil cleance is spot on as well within spec. I will be getting it all thrown back together with a new radiator as well. The problem i have is i have gone over budget on this build and since everything i have listed is new and wondering how much could I get for this car? If comes to it as its way to much money after this over haul. So let me know! thanks for your time
Body has the standard rear wheel well rust and interior is fairly decent no stains ac works and power windows work and hatch has new struts as well
Thanks @TMF but I just bought a 2001 Ford Ranger. This would have been right up my alley though. Glws Op.
