Shes missin bad
Discussion in 'General Subaru Discussion' started by whistleandsneez, Oct 4, 2005.
  1. whistleandsneez
    whistleandsneez New Member
    my check engine light came on my on wrx and when it turns on it misses really bad at first but then as the motor gets warm it isnt so bad but still misses anybody know what that could be
    04 wrx
    intake
    hks bov
  2. Steve-o
    Drinking.
    nice job at only putting on the 2 mods that are not recommended for a stock ecu'd car. I'd take them both off and reset the ecu.
  3. readymix
    Eloh, El
    Yep, the HKS bov is full atmosheric which is bad for your car (causes rich conditions at shift) and Intake (any brand) which causes lean conditions and MAF voltage skewing.
    Nothing throws the CELs like making things rich when they need to be leaner and making things too lean when they need to be rich.
  4. wall of tvs
    dream ftw
    Hmmm....sounds like a misfire, perhaps. Do you know what codes you are throwing?
    I'd pull the plugs and inspect the coilpacks.
    ....also, ditch the intake and BOV. ;)
  5. Dynapar
    Orono, MN
    might try new plug wires, if nothing else works.
  6. AWDimprezaL
    Monticello.
    FYI rexxes dont have plug wires, they have individual coil packs
  7. Dynapar
    Orono, MN
    blah blah blah....... maybe if he had plug wires he wouldnt have this problem????
  8. Zola
    Zola Well-Known Member
    St Louis Park
    Fouled idle air control valve. Your symptoms are exactly what I experienced, cleaning the IACV with some Seafoam took care of it.
  9. whistleandsneez
    the car had the miss before the blow off valve was put on and the intake
    thanks for the suggestions guys
  10. kongzilla
    kongzilla Well-Known Member
    Maplewood
    I had an intake and hks bov on my old 02 rex. no problem at all. after installing a turbo back exhaut, started having mis firing once in awhile.
