shifter karts
Discussion in 'Off-Topic' started by Troutbrookrally, May 8, 2008.
  1. Troutbrookrally
    Troutbrookrally New Member
    I'm contimplateing swapping a crotch rocket motor onto a shifter kart. I'm sure many of you have seen them on youtube, Im just curious on what kind of problems you guys think i would run into. Also any ideas on how to make the transmission/ shifter work everything else seems pretty staight forward. any help would be great thanks.
  2. readymix
    Eloh, El
    You would need to come up with custom linkage. I ran into this a few years ago with mine. Ended up selling the chassis instead. What size motor do you intend to go with? I wouldnt recommend anything over 600 if you want to keep your skull in one piece.
  3. Paul Revere
    In the land of ice and snow.
    Go with a 500cc 2 stroke or if you wanna really rip get a newer KTM 5xx 4 stroke motor, either way that kart is gonna move. Sadly it would more than likely be quicker around the track with a 125 pinger/250 thumper less weight still 35-40 horsepower.
    My $.02
  4. readymix
    Eloh, El
    GSX-R 600. Go man, go. THat was what I wanted to use on my cart before I sold it.
  5. AWDimprezaL
    Monticello.
    older inline 4 cyl sportbike motor, my father has a honda intercepter v4, they make about 90 hp?
  6. TSTRBOY2004
    I wanted one like the gixxerkart...
    I am trying to get my dad to send me my go-kart from OZ with the yz80 engine...
  7. Troutbrookrally
    yeah I am looking at like a 600. this is just a project me and my dad are contimplateing doing when i move back home in june. its deffinetly going to take something on the whole transmission setup but i should know very soon if we are going to attemt this because I found a great deal on a kart in forest lake. if you guys think af any other things i should look for let me know. i appreciate the help
  8. readymix
    Eloh, El
    THe transmission from the 600 motorcycle of choice should be fine. Just the linkage that you have to figure out.
  9. piddster
    Boostonia
    Thats a lot of motor to put in a tiny little shifter cart. And I'm just referring to size. A sportbike motor works out much better in Formula SAE style of car.
  10. Troutbrookrally
    yeah its just for fun really, I have a large paved road loop(about 2 and a half miles it will be perfect to open this thing up) around my house and i want to go out and show the two nieghbors who always rip around it in thier karts something new. And yes i do realise that this is way to much puwer but thats half the fun of it right.
  11. piddster
    Boostonia
    Very true. It'll just be funny to see such a large motor on it, lol.
  12. flstffxe
    flstffxe Well-Known Member
    Coon Rapids
    Just out of high school a buddy of mine and I did a buggy with Gsx1300r engine that we received out of a coworkers wrecked bike('99 busa). We took the front suspension from a 2wd S10 along with all the brakes. For the rear we used the front suspension from a 4wd S10 minus the brakes but used the axle shafts and the adjoining flanges from the differential which we mounted on a shaft on a set of self aligning bearings with the sprocket and brake rotor also mounted on the shaft to drive/stop the rear axle. Shocks were made by works performance(coil over motorcycle shocks) for us and netted about 18" of total travel on all 4 wheels. With a set of 10" comp TAs you could take a 6" curb at 60-70mph and never feel it. We never topped it out but we do know in 4th gear we could pull away from my '95 f-150 at 100mph like the truck was standing still. Our build cost was less then $2500 all said and done(shocks were $1400, but worth ever penny) Denis was offered $6,000 for it, and it was sold.
