Shifter question
Discussion in 'Modifications And Maintenance' started by Scuba Steve, Apr 13, 2006.
  1. Scuba Steve
    Okay, so while driving normally I've started to notice my shifter bouncing around a bit, especially in 3rd or 4th gear. I understand since it's all stock I should notice some movement, but it's now become a quite a bit more.
    Any suggestions/advise on cause and a remedy? Transmission mount weak or flexing? shifter bushings worn?
    I've never worked on that part of the car so I'm a bit confused.
  2. Scuba Steve
    can anyone help with this? Any advise would be greatly appreciated!!!
  3. idget
    I cant give you a technical answer but replacing the front and rear shifter bushings with kartboy ones reduced the "bounce" for me. The stock bushings are as rigid as a pencil eraser.
    Yr talking about how the shift knob looks like it moves aound a bit when in gear right? Thats normal (to a certain extent).
  4. Scuba Steve
    yes, exactly what I'm talking about....and it seems to be getting worse. bushings? I've been told I should've installed bushings and a short throw a while ago....
    thanks
