Shifting into reverse problem?
Discussion in 'Modifications And Maintenance' started by Sky58, Jan 16, 2007.
  1. Sky58
    Sky58 Well-Known Member
    Ok, so this is my first winter with the Suby and what I've began to notice is that eversince the weather has gotten colder, it's harder for me to shift my car into reverse. All the other gears are fine, but it's only reverse that has the issue. It just won't get in there and if I try to let up off the clutch to see if it catches, there is a grinding noise so I think the reverse synchro is a little screwy. Once I fiddle with it, I can finally push the shifter into reverse and it's fine. Just curious if anyone else has this issue or is there something else I should take a look at?
  2. Steve-o
    For some reason this usually works for me I put the car in 1st and let the clutch out a little. Then it will usually go into reverse fine...
    The beauty of the subaru 5 speed. :eek:
  3. Deride
    Yea, mine does that.... gotta shift to first then try.... and keep going first/reverse until it goes.
  4. Sky58
    Ok I'll give that a try though it's freaking annoying when I want to pull out of my garage :squint:
  5. Deride
    Yea, sometimes just rocking the car by shifting back and forth in your seat while holding the clutch in and pulling back towards reverse works. It is definately more picky when it is cold.
  6. bikerwriter
    bikerwriter Well-Known Member
    Most cars do not have a synchro for reverse, and shifting is always harder in the cold. You might even have trouble shifting into first unless completely stopped. Now, if you say you have a heated garage and it never gets below 40 F, then I'd be worried.
    Oh, and don't be worried if you smell gas now that it is cold. It's infamous, but non-life threatening.
  7. Deride
    hehe, yea I smell a bit of gas when its really cold out. As for the first gear shifts, I seem to be able to get into first at 20-25mph when most people complain that you have to be completely stopped.... Might just be my RS tranny.
  8. Shibbs
    I have a hard time shifting into first and reverse too. And going from 5th to 4th, too, now that I think about it. Quite annoying.
  9. carl
    my STi has problems with 2nd in the cold. double clutching doesn't help
  10. webcrawlr
    webcrawlr Well-Known Member
    Yeah, cold and the gear box don't play well. I pretty much have issues with 1st and 2nd til it warms up. Reverse has never been an issue.
  11. carl
    yea after i drive for like 3 minutes it's fine. just annoying that first time i have to go into 2nd. bleh
  12. Zombie
    Zombie Well-Known Member
    werd! I have to slow down alot in order to get it in second and prevent a mild crunch of the synchros. Then a few miles down the road it shifts like butter. I park outside though. Even the resistance from the cold wheel bearings and diffs make it interesting down the driveway but that stuff warms up a mile or two down the road also.
    The original 5sp did this with subaru fluids and the FXT/BajaT trans i have now with uncle scottys cocktail does it. No big deal.
  13. Deride
    Scottys cocktail didn't help much for me, and it made my tranny WHINE like crazy at the ice race, I'm going back to normal 75w90 after winter.
  14. Xcelor8
    Xcelor8 Well-Known Member
    Scottys cocktail didn't help this issue with my car either.
    I found if I let off on the clutch just a little bit it'll slip in much nicer.
  15. Sky58
    Yea, I was reading about that and was thinking of giving it a try, but now I know it won't help this issue :)
  16. LesMiner
    LesMiner Active Member
    Same problem here with reverse and at times 1st. One of the 06 WRX reviews had a similar complaint on their test drive. I wonder what would happen if winter weather returns to the 30 below temps? I have had MTs in the past that in really cold temps you could barely move the shifter let alone get into gear. Lots of posts on NASIOC and other places with the same complaint. Where is SOA on this problem?
  17. AWDimprezaL
    try going into 5th before reverse, works like a charm for me every time
  18. Bullwinkle
    Hrm, my '06 behaves in the bitter cold just like any other manual car I've owned. Slushy gears till she warms up, and I can hardly get her into first unless I'm completely stopped. No problems at all with reverse, however.
  19. webcrawlr
    SOA can't do anything. It's a 75 weight oil cold.
  20. bikerwriter
    Thankfully we have "global warming" to help us out. :biggrin:
    The Subi shifter is balkier in the cold compared to my old SHO, but even automatics shifter slower when first started. It's just more of an annoyance in the Subi. I'll get over it, though.
  21. i_subie
    i_subie Well-Known Member
    I usually shift it into any gear first, if I'm in a hurry, then I would shift into Reverse after that.
    Otherwise, you can check your tranny fluid, or change your tranny fluid.
  22. stoooo
    stoooo Well-Known Member
    I usually just let the clutch out in neutral, blip the throttle and try putting it in reverse again. Occasionally, I'll have to give it a second blip, but that's pretty rare.
    Stuart.
  23. LVT
    LVT Well-Known Member
    i dunno, but i just pop mine into reverse and leave, even on a cold start. sometimes it hesitates, just go back into neutral, let off clutch, clutch in again and shift. give that a try,works for me!
  24. chokin
    chokin Well-Known Member
    it happenes to my car too ...so i let go the clutch a little bit then it will shift in even my 1st gear too ...thats weird
  25. Sky58
    Nope, still acting up not matter what I do lol There isn't a good way to do it it seems. I just have to keep shifting around till it finally falls in :squint:
  26. LVT
    it's a sign, give me your car!
