Shiny springs and advice
Discussion in 'Modifications And Maintenance' started by Sky58, Jul 9, 2007.
  1. Sky58
    Sky58 Well-Known Member
    Minneapolis, MN
    Moving onto to a little suspension work :biggrin:
    So, this is more than a "look shiny" thread and I'm just wondering if you guys have any advice that'll make my life easier when I install these. It'll be a first for me and I'll be using this link:
    http://www.iwsti.com/forums/showthread.php?t=52127
    as my guide as well as the '06 WRX service manual. I got all the tools I think I need (GearWrench, spring compressor, etc..) Any hints, words of wisdom, etc..is appreciated. Oh and I will be tackling this with hand tools. Thanks guys!
  2. Bullwinkle
    Saint Paul
    I've got a cordess impact wrench, if you'd like to borrow it. Shoot me a PM, I might be willing to come over and help out. I'll most likely be buying mine in the next couple weeks. :)
  3. Vector
    Vector Rally Organizer
    Nate,
    Depending on the timing, I've got air tools, a garage, spring compressors and some expereince (on Nissans, but struts are struts).
  4. Bullwinkle
    Saint Paul
    Nice! Thanks Mark!
  5. PRA4SNO
    PRA4SNO Well-Known Member
    nunyah
    Me and se7enrex did his whiteline springs in 2 hours flat. Struts are cake.
    They looked great.
  6. TSTRBOY2004
    if all goes well with an impact and the right tools it could be done in under 1.5hrs all four corners...
    Dont forget the alignement...
    have a gas-torch nearby in case... heat always helps rusted bolts, lots of penetrant (no penetration for Ray)... patience... it really isnt a huge undertaking, but if it is your first time.... go slower and do it right.. double check especially the top nut ont he sturt that holds the stut top on...
  7. Vector
    Yeah, and impact to take off the old bolts ithout ruining them, and a torque wrench to put them back on right.
    You will need an alignment afterwards.
    You running any alignment specials Nathan? I really need one now.
  8. TSTRBOY2004
    $50 (pretty much half price) is my special.... for mnsubaru guys... as long as I dont need to be pulling suspension apart to install camber bolts etc... ;)
  9. austinpike
    austinpike Well-Known Member
    Oakdale, MN
  10. Rexwagon
    Rexwagon Well-Known Member
    Fargo, ND
    nice springs
  11. curly2k3
    Silent Hill, Jackass
    looking good... especially the carpet, friggin BA man
  12. 1fastwagon
    1fastwagon New Member
    Edina
    I loosened the strut top bolt just a bit prior to taking the strut/shock assembly out...that was a lot easier than doing it after the fact...but I think that's in one of the iwsti write-ups anyway.
