Ok, anyone need anything changed in the shops area?? Let me know. I have it figured out how to make changes now. Russ
Well, right now I have to go into the database and make the changes. I could probably put together some code to make changes, but to make it secure, I would have to do some kinda of user sign in. The shops section is just a secondary database that has no direct connection to the vbulletin site. Russ
oh.. ok.. just thought it was like normal thread style stuff where you edit your own posts.. would make less work in the long run I thought but guess not... if you wanna change something on mine.. just add a last line .... Pipe Bending available SOON!!
I also sent you a pm to have something changed/updated in the shop section for Manochromatic! ~ Thanks!
is there a way to have it setup so more shops per page... like with a 2nd column or something... or maybe the Shops name that opens into the full details., kinda like the normal forum, where there is a thread name, when you click it, it opens the thread...
Sure, if you know how to do the code to make it happen. Right now it just pulls everything for the DB and dumps it on the page. Russ
