should I worry?
Discussion in 'Modifications And Maintenance' started by EggRoll, Aug 10, 2007.
  1. EggRoll
    EggRoll Well-Known Member
    Sometimes it doesn't always pop into reverse, at the the most I've had to up to three times. Is there something wrong with my clutch? I don't know too much but I'm trying, and yes I am stepping in all the way. I'm scared =[
    B<3
  2. Bielke55
    Mine does that too... ease the clutch out a little and itll bump into place...
  3. tangledupinblu
    Fairly common on manual transmissions. Like Brian said^^^ease the clutch out a little, it should slip into reverse.
  4. EggRoll
    ooo a lot of people have always told me to step down all the way, and always blamed me that I wasn't grrrr..
    Is that for all manuals of just some, cuz I don't remember my loose slutty honda doing that.
  5. prezawagon
    prezawagon Well-Known Member
    Mine does this all the time, sometimes putting it in first and moving forward a few inches then going into reverse works too. Otherwise yeah, let the clutch out just a bit, not so much that it grinds into reverse, but you'll feel it drop in.
  6. Bielke55
    My trans new and rebuild still does that... and sometimes makes noise just going back into first at a stop.
  7. rabbit
    rabbit Well-Known Member
    mine does that also. If it doesn't go in I put it in 4th gear and then in reverse.
  8. EggRoll
    alright thanks guys
  9. Speedemon
    Speedemon Well-Known Member
    When i had the 5 speed i would push it in 1st first then go to R...it seemed to work
  10. LesMiner
    LesMiner Active Member
    You are not alone. A lot of the magazine test drive reports mention the same thing about being hard to into reverse. Getting the car to move forward a liitle bit helps to get it into reverse. I had a Mazda that did the samething.
  11. John16V
    John16V Well-Known Member
    Same here too...
  12. pksublime
    pksublime Well-Known Member
    I thought my car was just being weird - guess not though!
  13. Bullwinkle
    Yeah, my '06 does this too. Usually a quick pop in and out of the clutch or shift into first then R does it.
  14. FuJi K
    [tiny fuji voice]
    I TOLD YOU SO!!!!
    [/tiny fuji voice]
