1. take the ram air intake out. 2. unscrew bolt that is inbetween ram air outlet and stock box inlet. 3. underneath the car infront of the pass tire there will be a square piece of skid plate plastic that you can take off. Take that off. 4. Take out the first plastic screw pos thing off the fender edge, its the one on the bottom corner. Pull plastic part way out. 5. rip out intake silencer box. You dont not need any type of pvc elbow. Plus that will just make it quiet again ...you wont be able to hear the air suckage, turbo spool as well.
behind the front tires, right underneath the side skirt. on the rear you should be able to find a place on the sub frame.
