Slipping Clutch
Discussion in 'Modifications And Maintenance' started by awdpirate, Jan 29, 2008.
  1. awdpirate
    Online
    awdpirate Guest
    Last summer my clutch began to die. It would act fine but when the turbo hit it would rev like it was in neutral and then eventually catch. In September, I had a new ACT flywheel and Exedy organic clutch put in. Now it is slipping when the turbo spools, the same thing it was doing 4 months ago. How can a new clutch go out after 1000 miles? Does it have anything to do with the cold weather?
  2. driftin240
    driftin240 Well-Known Member
    Did you install a new pressure plate?
    Was the hydraulic system bled properly?
  3. flstffxe
    flstffxe Well-Known Member
    +1 on that question
  4. 02blubru
    what is the proper way to bleed the clutch system? I think I know, but want to double check.
  5. Iroc-Z
    Iroc-Z Well-Known Member
    Just crack the bleeder and have some one push the clutch to the floor. Then close the bleeder and pull the clutch peddle back. Repeat as necessary. Also the hydraulic system would have nothing to do with the clutch slipping.
  6. flstffxe
    I am more curious about if a new pressure plate was installed.
    Other options are:
    The disc is glazed over from improper clutch technique, Operator error.
    A bad clutch disk from exedy
    A rear main oil leak that was never attended to when the new clutch was put in.
    A front trans seal leak that was never attended to when the new clutch was put in.
    Act flywheel was/is not flat causing excessive wear on the disc.
    Act flywheel was not heat treated properly and has worn premature tearing up the disc.
    All are possible options, but the end result is you will have to pull it out to find out. As for the bleeding; just like Iroc-Z said
  7. 1_sic_rex
    1_sic_rex Well-Known Member
    Proper break in period????
  8. flstffxe
  9. driftin240
    It wouldn't cause the clutch to necessarily slip, but if it wasn't pulling the pressure plate all the way off the clutch, it could be making some contact and burning the clutch surface whenever the car is running...
  10. Threshld1
    Threshld1 Well-Known Member
    I would like to add Oil baffle plate leak to this list
    Correction:
    Lame rear plate that does this and was at one time made of super strength plastic :roll:
  11. driftin240
    Good add, but some know it as the rear access cover...
  12. Threshld1
    I show "Cover oil separator" on the receipt ;)
    FYI if you pull the clutch, replacement PN's are:
    11831AA210 x1
    800406150 x1 (bolt)
    800406140 x5 (more bolts)
    Though if its not plastic RTV works well also
  13. driftin240
    Aluminum plates are best, but they are less common, and have been superseded by the stamped steel one.
  14. flstffxe
    add wrist pin access plug to the list
  15. Iroc-Z
    Yeah but then it would not shift right and you would grind gears. It sounds like your pressure plate may be damaged. Or you really know how to abuse a clutch.
