Snorkus removal = CEL?
Discussion in 'Modifications And Maintenance' started by blackozone, Jun 29, 2007.
  1. blackozone
    Help me out quick, I removed my intake silencer off my 02 WRX and now my CEL is on constant. I don't have anything to read the code, so I'm just pulling the negative terminal and resetting it. I did remove the upper airbox to have a look inside and unhooked the MAF during snorkus removal though. Has anyone heard of this problem before/have any insights?
  2. TSTRBOY2004
    nope... not from removing the snorkel part... I say recheck the maf sensor connections make sure you reconnected it correctly
  3. manochromatic
    manochromatic Member
    yeah maybe one time i knew this guy that knew a guy whos brother put the maf in backwards....:roll:
  4. blackozone
    I've checked the plug connections already, and I didn't actually pull the MAF out, it was the only sensor I messed with so my thoughts turned to it. I'm going to go hook the thing back up and start it and see what happens.
  5. Nuke
    what code number?
  6. blackozone
    Just started it up, no problems. One thing I did notice (caught me with my helmet on) is that I didn't tighten down the accordian tube to the airbox. :eek3: . HAHA, I feel so special...
  7. RichWRX
    RichWRX Well-Known Member
    I took the snorkel out last week and got a check engine light right away, reset the battery and have had no light since
  8. Bullwinkle
    +1. While the "mod" shouldn't cause a CEL, I reset the ECU when I did mine as well.
  9. inappropriatescreenname
    ok this is maybe a dumb question, but what's the snokus? is that the plastic tube in the fender that connectsthe air intake box where the air filter is, to the air intake at the front of the hood, and also connects to a plastic 'box' down in the right corner of the car?
    what's the advantage to taking it out... more airflow? what about sucking in water from in the fender, does that ever happen?
  10. Bullwinkle
    Yes.
    Yeah, there is minimal, if any, performance increase by removing it. Most people just do it to hear the turbo pulling air a little louder.
  11. blackozone
    Bov Pshh Ftw!
  12. blackozone
    Uh-oh...
    So I was driving the car on my lunch break today and another CEL came up. Anyone have a scantool I can borrow?:biggrin:
  13. Shibbs
    Any Checker/Autozone/most NAPAs/O'reilley..... Almost all of them are doing free DTC scanning.
  14. T-REX5000
    T-REX5000 Well-Known Member
    where are you located....find someone with an AP that can read codes
  15. EtchyLives
    EtchyLives Well-Known Member
    +1 on checker.
    As for power-increase by removing the snorkus: I did the following intake mods on my WRX:
    CAI: Nice increase in sound. Slowest times in the 1/4 (may have been because I was new to the car, but I did drive it that way for about 20 drag passes)
    No-snorkus: Got rid of the CAI because I got A/F paranoid and also added an AVC-R and didn't want to blow an engine. Results: middle ground 1/4 mile times
    Snorkus: Put this back on with the AVC-R and had fastest non-Reflashed tune drag passes
    Full intake with Original Cobb Stage 2 @93. Best 1/4 mile times.
    My unofficially validated opinion is keep the snorkus unless you're DYING to hear the BPV sound.
  16. 1_sic_rex
    1_sic_rex Well-Known Member
    Hey helmet..... You do have my phone number dont ya???
  17. blackozone
    OK, so the CEL is listed as P0303, third cyl. misfire. I'm wondering if this is working in combination with the light flywheel in the car, since it supposedly throws a CEL when switching to closed loop on occasion...
