So, what can an N/A 2.5 do?
Discussion in 'Modifications And Maintenance' started by piddster, Apr 26, 2006.
  1. piddster
  2. gc8
    gc8 Well-Known Member
    probably quicker than a WRX due to the weight difference and the gearing...and the whole no lag thing
  3. 6MTizzle
    6MTizzle 2SLO
    he's got a few dollars in there. with over 3 grand into my old RS I was able to make 130 whp and 140 TQ on a mustang :roll:
  4. gc8
    what did you spend the 3 grand on? The only thing he has that isnt very easily accessable is the P&P, otherwise he just has cams for internals which you can get reground from delta for like $150.
  5. 6MTizzle
    6MTizzle 2SLO
    Brullen catback, Cobb Equal Length Headers, Cobb CAI, N1 Light Pulley Set, Exedy Stage 1 clutch and flywheel, Cobb stage 1 driveline(bushings, tranny mount, short throw) I might be forgetting something but those add up to about 2900 and that's uninstalled with no shipping included.
  6. gc8
    cobb=expensive
    now there a more options like OBX where catback and header is about $500. The Delta Came Regrind i think is like $70 per cam...there are just cheaper options now than there were before
  7. AWDimprezaL
    n/a 2.5s are unreliable, piston slap, head gaskets, rod bearings ect ect nuff said, wrx swap has about a billion % more potential. but a fast n/a is nothing to sneeze at
  8. gc8
    the head gasket thing was just with the DOHC i thought...and ive never heard of anything about rod bearings failing
  9. AWDimprezaL
    no, SOHC's have head gasket issues too..probably worse, external leaks and all, think i dont know? i see them come into work every day.
  10. 6MTizzle
    6MTizzle 2SLO
    Fast N/A is awesome. My RS's torque curve went straight up...it was rockstar until I hit 3rd gear. For the money though its tough to beat boost.
  11. gc8
    i never have a large amount of money at any one point in time...so im just going to slowly build my NA. I know its never gonna be that fast, but i'm only in college. I have the rest of my life to have a faster car!
  12. kickin_81
    kickin_81 Well-Known Member
    ^^I'm rooting for you, man. Owning a N/A GC over other cars has its own benefits. At least you're not driving a Geo Metro or something else. Drive your GC for what it has and not for what it doesn't have.
    I miss my old GC for its hot body and simple layout, but I got a new car because I could afford a faster one, my GC packed 100000 miles on it, and I wanted slightly more room to carry groceries and the like. If I can get my hands on another GC for a low price, I'd kill for it. I'd kill something that won't fight back (like a plant).
  13. LVT
    LVT Well-Known Member
    I don't know about you but i've never heard of soch having head gaskets issues at all. my current RS has 104k and it looks like they never worked on the head gaskets as well. But can't argue if you see them everyday at work. I guess mine is just a lucky one =D
  14. gc8
    count mine in as a lucky one too then
  15. AWDimprezaL
    okay, come to MTK, i can point out 4 sohc's that are currently having headgaskets installed.....and one dohc, they dont blow internally, they BLOW externally. (though ive seen both) just ask subytek, or driftin240, they both have probably done them at least once this week. ask pete, your old car's head gaskets were shot at 20K ....but usually once they are replaced, they dont blow again, crappy stock gasket design. so you are both probably fine.
  16. gc8
    hmmm...wasnt aware of this problem. Thanks for fillin me in. (not being a sarcastic ****)
  17. LVT
    hmmm...i've always though the soch came with the newly designed head gasket that won't blow. the same updated head gasket that replaced that of the crappy 98 one. I guess what i read was wrong.......damn nasioc....lol...good info and heads up though.
  18. kwikrs
    kwikrs New Member
    IF you have an 00-01 make sure you get the coolant additive added so if or when if blow subaru will replace it for you.
  19. 6MTizzle
    6MTizzle 2SLO
    +1 My 01 blew a head gasket...needed the coolant additive. Subaru reimbursed me for it later.
