***SOLD*** For sale is one set of slightly faulty JNORTH fender braces. The only problem is that one has no strip milled out of the back, and one's strip is not quite completely finished. They aren't worth sending back, and I already have my replacement set with the milling properly done. There's no guarantee that they will fit without the milled strips, so they're being sold as is. $25 picked up in Eden Prairie, Bloomington, or pretty much anywhere in between. Stuart.
I have no idea if the milling is there to fit around something molded into the body shell, or if it's just to save weight. If it's just to save weight, then I guess one side of the car will be ever so slightly heavier than the other :biggrin:
Only confirmed to fit GC bodies with the appropriate holes in them (97+ I believe). I think they can be modified to fit the GD bodies by enlarging one or two of the mounting holes, but that's a rumour I can't confirm.
Stooo I'd like your review on this product when you get a chance to fully test it out. Many Thnx..........
Well, that'll have to wait until I actually get a new car to put them into, but I'll see what I can do. Fuji will probably have some feedback on them long before I do. Other owners have raved about them, but I guess it depends on how much other bracing you already have in the car.
