something is wrong
Discussion in 'General Subaru Discussion' started by whistleandsneez, Jan 31, 2006.
  1. whistleandsneez
    whistleandsneez New Member
    So i took my car out today just like any other day and it seems to die after like 5000 rpm and i mean DIE it drops boost and just doesnt have the power it should after 5000 does anybody know what this might be thanx
    ________________
    04 wrx
    short ram
    catback
    bov
    up pipe
  2. AWDimprezaL
    check your intercooler piping, sounds loose, didnt this happen to you pete?
  3. Chin
    Chin Well-Known Member
    Limp Mode? Boost Leak?
  4. whistleandsneez
    thanx guys ill look it over
  5. 6MTizzle
    6MTizzle 2SLO
    Check the connections on and around the intercooler. Those hoses and connectors like to pop off. You may have to put clamps on a couple of them...if you go down to firestone this weekend I'll show you which ones on mine needed additional clamping. Also check the connection from the ic to the engine. Mine slid off just a little bit but the clamp was covering the part that was loose so you could barely tell it was leaking(visually). Also is it making any noise? Mine you could hear something was wrong....it sounded like i had a turbo on both sides of my engine bay when those were leaking.
  6. SubarWRX
    SubarWRX New Member
    I've been having a problem kinda like that, good power till 4000 then it drops off till 5000 then it comes back on again. any thoughts?
  7. whistleandsneez
    yeah u guys where right it was the intercooler hoses leaking she runs smooth again thanx for the advice and i will be unable to attend firestone this weekend
