In an attempt to remove some of the Subaru clutter from my garage I am going to post as many items as I can in this thread. I will try and add items on a regular basis so check back often. R180 3.90 ratio. 125.00 was taken apart by owner for an unknown issue. I never had time to go through it. BOV adapter 15.00 Block heater 20.00 Push style release bearing 25.00 ACT pull style release bearing 40.00 Whiteline steering rack bushing kit 50.00 SOLD! GD change drawer 5.00 SOLD! K&N air filter for 1st gen WRX air box 30.00 Perrin 1st gen WRX inlet pipe 75.00 SOLD! Perrin after MAF hose 1st gen WRX 35.00 STI intercooler elbow 20.00 Continental tires 215/45/17 car they came off had some camber so inside is worn a bit. Still have plenty of life 50.00 for the set. Divorced cated downpipe for GR bodied cars cant remember the brand 140.00 sold! WRX shifter ass. w/kartboy bushings front and rear 50.00 07 STI bars 80.00 for the pair Perrin STI rear bar with end links and heavy duty mounts 140.00 Eastwood Fender roller 80.00 Sold! New Perrin rear sway bar and mount stiffening kit for 05-09 LGT 180.00 SOLD!
I could probably use that bov adapter. In going out of town for a couple weeks though. I could meet up Saturday probably.
Next on the blow off valve adapter, I could actually grab it whenever, that's all I need to finish my build
Sorry for the late responses. Sorry if your gone for a while is it ok to give it to E.procter to finish his build? I am in Eagan shouldn't be an issue to meet. If I don't hear back from him your up!
By all means, if someone needs it. I'm not even sure if it's what I think it is. What I was going to use it for is to, one day, fit a usdm intercooler on my version 4. The iacv is in the way of where the blow off valve would sit. I'm sure I could make one easy enough, if/when the time comes.
Sure I can ship it up there should be cheep since your close send me your details and I will get you a shipping quote.
Do you have a 06+ clutch laying around? Or a 02-03 iacv? I'm throwing p0508 and would like to try a used iacv before I stop a small fortune on a new one
