Just wondering what spring rates you guys use. I'm getting close to ordering up my suspension stuff...but am unsure what exactly to order. stock for my car is 132/196 front/rear. after the swap I've got a bit more weight over the front, so I figure the front can get a bit stiffer than the rear. I'll be running 20/16mm sway bars front/rear, with full poly bushings. probably also do some chassis stiffening, at least in the front. this is on a daily driver (and I deliver pizzas....so I put 4-500 miles a week on the car), and here in duluth we've got some serious potholes. I'm currently running 450/500 springs on stock shocks/struts.....and it's kicking my ass. I'll be running AGXs with ground control springs. I'm thinking either 200/250, or 250/300......thoughts?
I'd like to get into AutoX this summer.... and I do want some improvement over stock. but don't need an all-out coilover setup.
