Squeal When Heater Is On
Discussion in 'Modifications And Maintenance' started by mctenold, Nov 30, 2009.
  1. mctenold
    mctenold Well-Known Member
    2002 WRX. Just started to notice this when it started to get cold recently. I have had the heater on before, with no issues.
    Basically when I go to turn the heater on, I get a nasty squealing noise from the front of the engine (outside of the car). It sounds like a pig is getting slaughtered. This used to happen on my Civic when I turned on the A/C. Same noise.
    Anyway, it only seems to happen when the engine is cold. Once it warms up the noise goes away. I popped the hood and tried to figure out where the noise was coming from. I pinpointed it to here:
    Has anyone had a similar issue? Maybe it just needs some WD-40 somewhere. Although, I'm guessing the cold weather has something to do with it, but then again I don't turn my heat on that much in the summer, so who knows. ;)
    Thanks in advance for the help.
  2. predavore
    predavore Well-Known Member
    Ac? ....
  3. mnstilynwrx
    mnstilynwrx Well-Known Member
    mine does that to. I think the belt needs to be tightend?
  4. Bielke55
    AC Belt OR Tensioner Pulley most likely.
    If your using your defroster it kicks on your ac compressor
  5. Scuba Steve
    more than likley the AC belt. I suspect you have the HVAC setting to combo Defrost and Floor heat or just defrost? That setting will start the compressor as it's aprt of the system.
  6. mctenold
    Good call, I do keep my defrost on a lot of the time. Was wondering why it would be coming from the A/C.
    Thanks for the quick response guys!
  7. errorcode3
    errorcode3 Member
    just whatever you do, don't put wd-40 anywhere near the pulleys/belts
