stage 2 target boost
Discussion in 'Modifications And Maintenance' started by Skarecrow, Aug 8, 2007.
  1. Skarecrow
    Skarecrow Well-Known Member
    whats the safest boost one should be running on a stage 2 map for an 06 sti.
    my tables are showing a current target boost of 17.00
  2. webcrawlr
    webcrawlr Well-Known Member
    minneapolis
    Most tuned people are around 19-20 on pump/no meth.
  3. Skarecrow
    I wouldn't think a 20psi boost would be making your turbo all that happy.
  4. webcrawlr
    minneapolis
    Search. ;)
  5. Skarecrow
    i'm tired... searching will have to wait till tomorrow.
    staring at tables all night trying to figure stuff out on the new toys
  6. esperunit
    esperunit Well-Known Member
    Paris, 7eme Arrt.
    its a vf39 not a td04....
  7. kickin_81
    kickin_81 Well-Known Member
    St. Paul
    I get 17.5 psi on my stage 2 STi in the higher gears. Accessport V1.
  8. Dream
    south
    When did you get a STi??
  9. readymix
    Eloh, El
    He has an STi ECU, VF39, STi intake mani and intercooler.
  10. Dream
    south
    I know, that doesnt make it an STi. I was a joke but thanks for clearing that up Mr. Obvious. :roll: :laugh:
  11. Skarecrow
    Soooo captain topic change :) 17.5 boost is best for stock turbo?
    I don't want to go Pshhhhhhing my luck and get a boom noise.
    seriously now...
    best boost without hitting the danger zone.
    I'll log my stuff and post the log from 2 - redline.
  12. kickin_81
    St. Paul
    Mr. Redymix is correct. Since I've installed "STi" decals on my FXT, I've been calling an STi, also. ;) lol
  13. Dream
    south
    ric0r
  14. Bullwinkle
    Saint Paul
    Seriously, there are so many factors going in to this, it makes the question half worthless.
    Answer: There is no XX PSI is perfectly safe. There are a lot more things going on with an aftermarket (or the stock for that matter) tune then boost.
  15. wall of tvs
    dream ftw
    yeah, I can blow up a car with 12psi if I really want to
  16. webcrawlr
    minneapolis
    But he's too tired too search...
  17. tux121
    tux121 Well-Known Member
    Champlin
    Most people 17.5psi....Even on the COBB Stage II Sheets shows they tested at 17.5psi so its your risk if you want to go beyond what they tried.
  18. WRX1
    Over there
    The best amount of boost to run on a stg2 car (wrx or sti) or any car for that matter, is the most boost you can effeciently run and still have enough gas to support the air flow. there is no magical number that works for everyone. Since I have been tuning the wrx since a tunable em has been out, I have done many stg2 cars that will run 2-3psi different. So cars just have better injectors that will flow more, so you can run a bit more boost. Some motors flow a bit better. Way to many variables to say run "X" boost.
  19. w_o_t_boy
    w_o_t_boy Well-Known Member
    Seattle
    You should probably have an EGT gauge if you want to go above 17.5 psi on pump gas.
    I ran like 21 peak boost through my td04 on E85. Tom ran something like 19 on the stock turbo and pump gas when he had a 2.0l car. You just have to watch your injector duty cycle numbers 'cause you can't run that kind of boost much past 4000 rpm with stock injectors.
  20. mlgez
    mlgez Well-Known Member
    Around
