Stereo Install
Discussion in 'Off-Topic' started by Moleness, Jun 7, 2007.
  1. Moleness
    I am about to start attempting to install amp wiring and, later on, a CD deck in the STi. I have done this before, but not in the Subie. Anyone bored today and wanting to join me? I would provide beer if this were the case :biggrin:
  2. pksublime
    pksublime Well-Known Member
    during the day or later tonight?
  3. angusracer
    angusracer Well-Known Member
    i'm too far away. but i would help if that weren't the case
  4. Moleness
    Gathering parts right now, probably going to get something started momentarily, but it may take all day since I don't know where to go through the firewall, how to get past the backseat, or how to even get the factory player out...
  5. Moleness
    Thanks anyways ;)
  6. pksublime
    pm me your number and i'll give you a call when i leave work
    if you want my help that is
  7. weggy
    weggy New Member
    Do you have everything that is needed for this project? A lot of people forget about the dash kit :p. If you need me ill shoot over and help, pm me.
  8. angusracer
    firewall... the whole is right behind the intercooler about a foot down more towards the drivers side... you may need to unbolt the rear seat... i have a wagon so it folds and stuff... the factory deck comes out via phillips screws behind the trim which is held on by clips... so a pry tool may be needed the first time... good luck
  9. angusracer
    oh the whole in the firewall is plugged with a rubber plug... or you can follow the boost guage line that t's with your stock bpv...if equipped
  10. angusracer
    oh and don't forget to save the bracket that is screwed to the factory player... i made the mistake of selling my 6 disc with the bracket before i installed the aftermarket
  11. 02blubru
    as far as I know most after market decks and be isomounted into our cars. The only thing that would be needed if it is not a double din is a plate, or a pocket for the extra din spot. I know I did not need a dash kit in my car, heck none of my 3 subarus needed dash kit.
  12. Moleness
    Hmm, well I just got a dash kit that includes a pocket, so that part should be all good
  13. Moleness
    Thats kinda scary... I was about to start disassembling the console to get to the factory one, but you can just stick something like a small screwdriver in there to pop the frame off???
  14. Saabaru
    Saabaru Well-Known Member
    Yeah all you need is the pocket, everything else screws right in nicely. Be easy on the trim if it's never been taken off, it's easy to crack. Use a cloth or somthing over your pry tool. You should be able to sneak those wires behind the seat into the trunk too.
  15. Moleness
    I thank you all very much, I am going downstairs to check it out now ;)
