Yes, I snapped the plug with the harness in it.. The top plug. You have one? You'd be a savior... I have an event tomorrow.
Yes, temperature signal for the rear diff fluid. I didn't just snap the sensor though...I snapped the whole plug. I drove it but I couldn't tell if I was actually losing fluid or not. Guess I'm not participating tomorrow
I should have clarified, I don't need the plug from the harness, I need the actual plug that goes into the diff.
Here's the part number: 27043AA020 And I discovered the 08 is different than 04-07 sti... The inner plug on the 04-07 sti has a 30mm head and the 08+ is 22mm and it doesn't look like the 30mm will fit. Here is a pic... It's actually a temp sensor plug that goes into a bigger plug. Might have to bend over and buy one from the dealer.
http://parts.subaru.com/p/Subaru_2008_STIWAGON/SWITCH-ASSEMBLY-THERMO/49236403/27043AA020.html Ps, the 44 ft-lbs torque spec in the FSM is for the larger plug, not the sensor plug. Learned that the hard way!
Yup, I'm glad I at least don't have to pull the diff! Sounds like this is a common problem since the torque spec isn't very clear in the FSM. It was kind of stupid if me to torque that plug anyway.
I just put an 08+ r180 into my car and it didn't have the sensor. Just the adapter plug. I jammed an 3/8" NPT threaded pipe plug in to seal it up.
