sti utec shipped. /dancing banana
Discussion in 'Modifications And Maintenance' started by DISCOPOPE, Aug 19, 2004.
  1. DISCOPOPE
    DISCOPOPE Well-Known Member
    :D
    /cheer.
    it should be here tomarrow.
  2. Zola
    Zola Well-Known Member
    Nice...if it doesn't come with the updated firmware, make sure you do that right away. Version 1.1c is out just in the last couple days.
  3. DISCOPOPE
    yep thanks. i will make sure i dl that right away..
    still need to find a cheap laptop... all of ours here are macs..
    i'm going to walk into this slowly.
    probobly bugging the heck out of you utec gurus.
  4. igofast
    igofast New Member
  5. RichWRX
    RichWRX Well-Known Member
    Mine finally came in this afternoon,cant wait to hook it up
  6. DISCOPOPE
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by igofast
    How cheap? I have cheap and cheaper for sale. Look here:
    http://www.mnsubaru.com/forums/topic.asp?TOPIC_ID=712
    $50?
    sold!
    i have the cash right here in me pocket.
    612.379.2321
    -aaron
  7. DISCOPOPE
    ok, so i was able to install the utec in under an hour last night.
    i did not install the abc, as i do not intend in the near future to be running that much boost.
    also, on the map switch, in addition to the clutch switch leadsm there is a pair of short wires coming off.
    black and red.
    there is zero documentation on these wires?
    please help clue a noob in. what are these!!
    initial reaction to the utec.
    very nice improvement up top.
    the boost seems to come on with more pizzaw, it hits harder...
    i didnt push it with the base maps, just made a few pulls up to 5k
    the car feels a little herky jerky arround 3k.
    i'm guessing that this is where one needs a good tune, to ramp things up correctly.
  8. bikerboy
    RTFM! I love doing that. Your red wire and black wires are in there in the back couple of pages.
    They are the leads for the additional accesories that the utec can trigger
  9. WRX1
    Post up a log of the hesatation that you have and I can probably fix it for ya real fast. If it is just the crossover point stuff, that is real simple to fix. Also, the red black wires are for the utec's extra output (water spray, nitrous, etc). The black wire will go to ground, and the red will got to a relay to control what you want.
  10. DISCOPOPE
    ty, matt russ, yes i figured it was the solinoid leads after getting logical and reading the manual for the 4th time. afaict nowhere are they directly labled in the manual, or the remote switch packsheet. i just looked at the pin outs, and figured it out.:D
    my cheap as hell laptop should be coming in tomarrow.
    i'll post some logs in the pm.
    thanks!
    :p
  11. DISCOPOPE
    i'm having issues saving logs on my cheap as hell laptop.
    mostly cause im dumb.
    :D
