STI vs WRX fuel pump?
Discussion in 'Modifications And Maintenance' started by shane86, Jun 2, 2008.
  1. Shane86
    Shane86 Well-Known Member
    Just curious....
    is the STI fuel pump a diffrent model than the WRX?
    how about the 2.5L WRXs?
    and mainly for the parts guys... do the 2.5s share the same P/N as the 2.0s?
    the competitive little guy in me is seeking the "Really really close to legal" mods... just get the little extra fuel so the damn injectors aren't bouncing off the 100% mark.
    a walboro is totally out, as you can hear those ****ers from a mile a away.
  2. Dream
    You couldnt be more wrong.
  3. Threshld1
    Threshld1 Well-Known Member
    I think my walbro is quieter then the OEM pump...
  4. jonny8852
    jonny8852 Well-Known Member
    i have had mine walbro for 2 years now and i barely even notice it. It only makes noise for like 3 sec. just do it:biggrin:
  5. Paul Revere
    Yeah I just put mine in, you can hear it if you prime it but otherwise I don't even notice.
  6. idget
    Per the nasioc fuel pump FAQ:
    2002-2005 WRX fuel pump 130 lph
    2006+ WRX fuel pump 145 lph
    2004+ STi fuel pump 145 lph
    and iirc both wrx and sti use a 30 psi fpr.
    No clue about the PN but I imagine the 145lph version may be the same.
    Can you do injectors?
    02-05 WRX uses high impedance top feed injectors - 420 cc
    04-06 STI uses high impedance side feed injectors - 535 cc
    06+ wrx and 07+ STI likely use the same injectors (not sure on this one) they use high impedance top feed injectors - ~560 cc
  7. B-REX
    B-REX Well-Known Member
    If your looking at it as a money saver it won't get you far. I would just get one if I were you. If you don't do mods that you should, it just creates issues. Sometimes BAD!
  8. webcrawlr
    webcrawlr Well-Known Member
    A pump isn't going to lower your IDCs. Bigger injectors will though. Have you checked your fuel pressure to see if it's dipping?
  9. idget
    I'm guessing this is for autocross... update/backdating rules.
    Also, you can buy almost 3 walbro pumps for the cost of an oem pump new :laugh:
  10. Nuke
    I wonder if the 190lph is any louder than stock
    If not, you can grab one of those.
  11. WRX1
    Either way, when you are maxing out the injectors, it doesn't matter what pump you have, you need bigger/more holes in the bottom of the injectors. The only thing you can do to lower idc's is increase the fuel pressure or install larger injectors. A pump will only help you if you can't get the fuel to the injectors fast enough. I know from back in the day, guys were running 700cc injectors on the stock wrx pump without any problems. Most times, the pump is just cheap insurance, not really needed (stg2/small turbo cars).
  12. AWDimprezaL
    Just a quick question..... on an auto-x course, why are you so heavily concerned with your injectors being maxed out when i bet you hardy get out of 2nd gear? i can see it being a bigger issue on drag strip, or road course. Just my .02
  13. tux121
    tux121 Well-Known Member
    Are you kidding? I can't even hear my Walbro! I can hear it in my brothers car because its known to be very annoying in the Evos, but there is no sound in the WRX/STi unless you but your ear by the gas tank and really listen. I've tried it.
    I believe the difference in the 02wrx and sti's are going from 130lph to 145lph???
  14. B-REX
    Oh, I didn't know if it was for autocross either. Considering he said he was just curious... Than why not just buy a walbro?
  15. B-REX
    But now that I look at it I guess that's why he did say "Really really close to legal"
  16. curly2k3
    knowing your set up, i think you should be focusing on other things if you are maxing out the injectors right now
