Sti wireing help
Discussion in 'General Subaru Discussion' started by RichWRX, Apr 3, 2007.
  1. RichWRX
    RichWRX Well-Known Member
    Is anyone good with wireing or know anyone that could look at my car. I may have melted some wires last year and want to be sure everything is ok before I get a tune.
    Rich
  2. RichWRX
    anyone?
  3. piddster
    I'll take a look at it. Find me a factory wiring diagram and the install maual for the ECU. We can make absolutely shure your grounds are good. I welded a couple studs to my floor for grounds. I've have no issues in 4-5k miles.
  4. Grayguy
    Grayguy Well-Known Member
    I Back his wiring abilities 100% after seeing him do his motor swap!
  5. RichWRX
    where would I find the manual and wiring diagram?
    does anyone here have one??
  6. 02blubru
    brian shortnen or driftin240 or anyone else that works at the subaru lots could maybe get that info for you.
  7. Threshld1
    Threshld1 Well-Known Member
  8. RichWRX
    04 sti
  9. Dynapar
    +1 brian (err shorten that is) helped me get a hold of the engine harness diagram for my car. that diagram is indispensable.
  10. Chux
    I could probably come give you a hand if you'd like...where's the car?
    you're not using the stock ecu anymore...are you?
  11. RichWRX
    not the stock ecu, Hydra.
    It will be at Justins shop on friday night, and we will be looking at it saturday sometime
  12. Justin
    Justin Well-Known Member
    anyone is welcoming to come over. maybe we can get some food, chill, and work a bit
  13. RichWRX
    if you have a way to cook it I can get some sausage
  14. Justin
    phil supposedly has a deep fat fryer
