STI/WRX stock weight and reductions
Discussion in 'Modifications And Maintenance' started by 01midmetws6, Oct 15, 2012.
  1. 01midmetws6
    01midmetws6 Well-Known Member
    So I have been getting a variety of information about what our cars are supposed to weigh in stock form. I weighed my car this summer (04 STI) at the Proving Grounds event and it tipped the scales at 3360 lbs as it would come off the street w/o driver (spare tire/jack, half tank of fuel, etc). Some have told me this is about the norm while others have insisted that the car should weigh closer to 3150 lbs.
    So here is what I am looking for:
    Vehicle weight w/o driver (I don't want to do any math)
    What has been done to lighten or add weight to the vehicle
    I am concerned about the GD chassis but if others would like to post I am sure there would be interest.
    My hopes are that I can dump literally 200lbs off my car this winter without loosing driving comfort. I do have corner balance scales that I can borrow from a friend and will continue to update my progress along the way.
    Edit: Stage 1 of weight reduction is underway and all aftermarket stereo stuff and dynomat is removed. Lost a total of 46.4 lbs, not the 50 that I was looking for but a good start non the less. I also have the front bumper facia removed and am waiting on Oswald perf bumper beams. I have to get the car put back together so I can tear the trunk stuff out and rear bumper as well. Updated pics on page 2.
  2. project/driven
    My 02 WRX weighed in at about 3150 with a half tank of gas. I think the STi picks up some weight with the bigger brakes and beefier trans. The wxtra 150 or so lbs sounds pretty reasonable for the upgraded hardware. I think to lose 200 lbs the AC is going to have to go on an STi. I might be wrong about that, but I am having trouble thinking up places to lose that much weight without sacrificing comfort.
  3. idget
    200lbs is doable for reasonably cheap. Aftermarket seats, battery, jdm (or no) bumper beams, gut the sound deadening, ditch the ic sprayer tank, rear wing, jack, and spare. Airbags are pretty heavy too.
    Id also look into freeing up some unsprung weight. Tons of options there.
  4. 01midmetws6
    initial thoughts are as follows:
    bumper beams 50
    header 15
    spare tire/jack 20
    battery 15
    stereo stuff, dynamat, wiring, amps 50-60?
    IC sprayer, rear wing 20?
    other stuff 20-30.
    Bingo.........200lbs!!
    I will start tearing stuff apart and document over the next couple weeks.
  5. idget
    Yeah shouldn't be too tough. I wanna say I was down to 3080 in my 06 wrx with just header back exhaust, coilovers, wheels, tires and no spare/jack. So that's 100lbs right there.
    Hoping my next car is under 2000lbs :)
    Mr.Tran likes this.
  6. Moleness
    I also weighed in there, '04 STI as well.
    -less front bumper beam (FMIC)
    -coilovers are lighter than stock suspension I would imagine
    -trunk stripped, tire/jack removed (including ic spray tank)
    -no hood scoop/wing
    -Optima red-top in trunk (doubt I lost weight here, lol)
    -no windshield washer tank
    -no a/c parts form firewall forward
    -evap system gone
    -engine wire harness shaved (5oz or so, lol)
    -Fobia header/turbo piping stuff is prolly less than stock???
    1/3 tank of gas, without me in the car, 3075lb
    *have since removed middle rear seatbelt ;)
  7. project/driven
    Shows you what I know. Looks like there's some more weight in my car yet. Stock seats are still in mine. I have a front mount that replaced my bumper beam, so not as big of a loss there. I remember it was 3265 with me and gas when I pulled onto the scale.
  8. 01midmetws6
    Your car weighs 300lb's less than mine! The only items I see on there I will not be doing would be the A/C and I will be going to a lighter trunk mounted battery. Definitely gives me hope!
  9. Nuke
    Charcoal box
  10. TMF
    For unsprung weight...lighter wheels could be a big helper. IIRC, you're running rota's? Those are at least 20 lbs per wheel. Pick up some Enkei RPF1's (17x8, approx. +48 offset) and you're looking at about 15 lbs per wheel.
  11. 01midmetws6
    The only issue with running a narrower wheel is the stability issues that would be caused by running a 255. Especially in the RS-3's since they have such a soft sidewall. Plus I love the look and fit of the wheels!
  12. TMF
    Well, you could fit a 255 on a 8" wheel...but probably better with an 8.5 or 9. You can also get the RPF1's in 8.5 to 9" width as well. Just a suggestion, as Rota's are typically not the light nor strongest wheels for racing (although I used to run them on my last car!). And actually, the wider and lower offset RPF1's look much better than the 8"/higher offset ones.
    There are other Enkei's styles, SSR's, etc that are lightweight as well.
  13. Moleness
    It is hard to find an rpf-1 in anything other than 17x8 on a 5x100 bolt pattern. That starts to get a bit narrow when a you start to make a lot of power. I have heard that rota dpt's, for example, are under 20lb in a 17x9. I will be able to confirm or deny this as soon as my old rubber comes off of them pretty soon here.
  14. 01midmetws6
    I did not weigh my 17x9 Grids but they did not feel too heavy compared to similar wheels I have lifted onto the tire machine. They are considerably lighter than my 18x9 G-forces.
  15. xluben
    Grids in that size will be 20+ lbs for sure. 17x9" 5x100 RPF-1's are special order, but they are supposedly going to be a stocked item now that the BRZ is out. I have the Mach V wheels. They're 17x9" and weight under 18lbs.
    FuJi K and Nuke like this.
  16. tangledupinblu
    A 1/4 tank of gas instead of 1/2 would be a about a 30lb. weight reduction also! Lol.
    5 speed swap?
  17. ofspunk7
    You forgot. Grids carry a -20lb weight reduction spell. This is due to their level 5 magic coolness.
    Silly noob
  18. 01midmetws6
    Do they make RPF1's on a +42? Mine are a +42 and just touch on very hard cornering right now. Enkies are so spendy.....ouch!
  19. 01midmetws6
    I can handle the 1/4 tank mod but don't have plans of dumping a gear.
  20. tangledupinblu
    Are you racing mainly autocross or big track stuff? I would think that on big tracks the 5 speed would be at an advantage with the longer gears...AutoX on the otherhand, probably not as much.
    I also wonder what the actual weight difference between the 5 and 6 spd are?
  21. Nuke
    About 100lbs
  22. tangledupinblu
    Dayum, that's alot of weight, good deal! That means my tranny offsets my bangin stereo addition in comparison to an STi.;) lol
  23. ofspunk7
    FIXED :cool:
    Silly tranny banger
  24. TMF
    Not sure if anyone talked about this at the track...but I'd always keep your fuel level above 1/4 tank, maybe even 1/2 tank for the full track (unless you have an aftermarket fueling system I suppose). I experience some fuel cut on my saabaru at an autox when I had about 1/4 tank...never a good feeling!
    Josh...dumping the six speed is just silly! (for obvious reasons) :p
  25. Nuke
    Don't worry about Josh. He doesn't know what he's talking about :p
    As long as a surge tank is installed, it should be fine
  26. tangledupinblu
    Quoted for truth!
  27. 01midmetws6
    Mine runs out coming out of turn two with anything less than 1/2 tank, so when I run it is full to the top, surge tank should fix that this year!
  28. KA-T_240
    KA-T_240 Well-Known Member
    Generally its the other way around I think. The WRX has better gears for auto-x because you don't have to shift as often. Most can put it in 2nd and forget about it. When it comes to the STi, many(modded) have to shift between 2nd and 3rd gear. On the road courses, the 6 speed's gearing provides you with the opportunity to always keep the car "in power" vs in the WRX you can get into spots where you are out of the power band and going to fast to try down shifting. At BIR I could basically leave my WRX in 3rd and 4th thru most of the short course which is nice as it allows me to work on my lines more then shifting; however there were parts where i was bogging in 3rd gear, but going to fast to make any use of downshifting further. Maybe a certain BIR Instructor can shed some more light on this subject? :)
    Other advantage of the STi tranny are the LSD's not sure of their actual impacts when road racing.
    Shane86 likes this.
  29. KA-T_240
    On the subject of wheel weights, my buddies 17x9 grids weigh less then my 17x9 Gram Light 57ds.
    A good very light wheel is the Volk CE28, its expensive but I believe the 17x8.5 weights just shy of 15lbs(Don't know if that is correct, but it should be close).
  30. 01midmetws6
    How durable is a 15lb wheel. You would think they would bend just looking at them.
  31. KA-T_240
    Volks have been used as racing wheels for a long time. Its all in all the way the wheels are made. RPF1s are great racing wheels and they are light, they may seem expensive, but a Volk will be double the cost of the RPF1.
    Nuke likes this.
  32. tangledupinblu
    Very durable! Forged wheels ftw.
  33. TMF
    Well, after driving a 5 speed in autox and moving to a 6 speed (only for one event so far), I can say it really depends on the course. The 2nd gear on the 5 speed is often times geared way too high for coming out of the sharp turns and tends to bog. While the STi 2nd is great for picking up speed from sharp turns...there were courses that I ran out of gear in 2nd in my 5 speed...I can only imagine what will happen in the STi!
    Anyway, back on topic...lighter wheels, yes. But, I would be curious to find out just how heavy your rota's actually are, before you go chasing after only a couple lbs. Do you have the actual size specs on the rota's?
  34. 01midmetws6
    So i am going to be doing new bumper beams as the first part of this reduction. What are the advantages and disadvantages of the Oswald or JDM beams? Also is there a jdm rear or just a front? I am having issues finding pricing and availability on the jdm beams. Any thoughts?
  35. KA-T_240
    I'd start by searching the forums(nasioc and iwsti) for someone who has one for sale. Follow by vendors, I know some vendors used to bring them in. Lastly, if you have no luck, I know some canadians that import cars/wheels/parts that would be able to get it for you. Probably wouldn't arrive till spring tho.
  36. 01midmetws6
    I was looking more for something next next week. My car was hit in a parking lot and the front bumper is getting replaced. I am going to start tearing stuff out of it next week/weekend and then put on the new bumper when done.
  37. idget
    So at what point do lighter wheels get negated by the heavier, wider tires that carry the extra weight at the furthest point from the hub center? And at what point does tire availability come into play. I ran into this issue when deciding between 18x11.5s and 19x12s, less of an issue with 17s, but something worth considering imho (depending on application). Speaking of application, when is it beneficial to choose the narrower, lighter tire and adjust roll center, camber, caster, and toe to make use of the available contact patch?
    Fwiw I ran smaller tires on my 2.5l wrx and taller tires on my sti to help out gearing ;)
  38. xluben
    ^I'd be interested in hearing thoughts on this as well. It seems that most autocrossers will throw on the widest tires possible. I assume that's because contact patch is much more important than weight on those types of courses?
  39. MNGman
    MNGman Well-Known Member
    Usually for Autocross wider is best. It will really depend on the class. In some classes you are limited to a tire width. In the class I run, I'm limited to a 245. All of the fast guys are putting that on a 9" wheel to try and maximize the contact patch. With the stock classes, you are limited to the stock wheel size, so as much rubber you can fit is the way to go. Almost everyone will try to find the lightest wheels allowable for the class. Less mass on the corners is always best.
    Race tires/slicks have very different properties that street tires. You are able to pinch a race tire/slick a lot more that a street tire. This obviously allows for a wider tire on a narrower wheel than possible with a street tire, again going for maximum contact patch.
    When you are dealing with only 6 to 8 runs a day,durations of 25 to 60 seconds, and with differences in time measured in the .001s, every little bit helps. :)
  40. KA-T_240
    That also depends on the the class you run in. In stock class, many try to put the largest tires possible on the car to get the most amount of grip(more grip, more speed through the corner). Stock class only allows limited mods(Struts, Tires, 1 sway bar, Air filter, Cat-back, and some other randoms), so tires is one of the biggest improvements you can make.
    I only ran 245s on my WRX, but that is what I had laying around. It will likely be what I keep running in STU next year.
  41. xluben
    Yeah, it seems that some guys in stock class have 265's on stock, 8" wide, WRX wheels! That's really pinched!
  42. KA-T_240
    Some of them are running up to 295s.
  43. Musashi
    Now that's a lot of cheese and crackers for two seconds off the clock. Johnny!
  44. idget
    Yup, that's the idea. The lighter weight will help you accelerate quicker, but autox is more about carrying speed and changind direction quickly.
    My rhetorical question was directed more to the op to see where his priorities really are, or if maybe he doesn't want to focus on just one area (like autox rules often force you to do if you get caught up in that hobby).
    I'm sure chongs answer is implying that if ones goal is to be faster, period. Start and end with seat time.
  45. idget
    Damnit it looks like ylime posted from my account when I post from my phone. Sorry about the spelling and grammar.
