stock axle back restriction
Discussion in 'Modifications And Maintenance' started by carl, Feb 13, 2007.
  1. carl
    we gotta gooooo
    How much difference is there going to be between a full 3" catless tbe system and a 3" catless dp + 3" midpipe + 60mm (2.36") axle back on a stage 2 EJ25? searching has yielded very mixed results
  2. shineynitelite
    st. paul
    i doubt anybodys going to have real results. i looked before. go on aim foo
  3. ShortytheFirefighter
    Which axleback? The diameter of the pipe doesn't automatically dictate how well it'll flow. The chamber type will have a large impact on it, as well as other supporting mods. What TBE?
  4. carl
    we gotta gooooo
    right now i have a JIC catback and an invidia dp. I'm considering switching to a turbo xs 3" midpipe with a 60mm axleback (brand is a secret right now :biggrin: but it is a straight through design)
  5. ShortytheFirefighter
    If it's a straight through, I can't imagine it'd be that much of a hindrance, if at all...One theory is that an exhaust that necks down near the end helps keep velocity up, especially since as the air cools it's losing volume and you're already several feet behind the turbo. Like I said, that's one theory. It sounds like you're around a stage 2ish car, a 2.5 in axleback would probably not have much of an effect if it is a straight through.
  6. carl
    we gotta gooooo
    yeah it's a "stage 2" STi. I won't be doing any crazy power mods for a while - this season is all about suspension. i could always add a cutout if needed
  7. shineynitelite
    st. paul
    why dont you get a mad dad mid pipe
  8. WRX1
    Over there
    Very true. I would guess that until you are over that 4-450whp mark, a 2.5 axle back will not restrict you. After all, it is just a 2.5l 4 cylinder and even with the boost you still really don't flow the air needed for a full 3" exhaust. As long as you have a good flowing muffler that is all that is needed.
  9. carl
    we gotta gooooo
    ok what do you guys think - should i get this axle back? it's a L'aunsort p555
    right now i have a JIC 505sus
  10. bikerwriter
    bikerwriter Well-Known Member
    St. Louis Park
    Didn't you just say you were at Stage 2 and NOT doing any crazy power mods, and that this year was all about suspension? :roll:
    I think you just want the bling. Ask Soggy for some pointers... :biggrin:
  11. TSTRBOY2004
    I would just buy that whole car.... mmm
  12. carl
    we gotta gooooo
    yeah and? is going from a 3" exhaust to a 2.5" a power mod? no not really - that's why i posted this question. if i was doing a bigger turbo I would for sure stick with the 3"
    reading and comprehension > you
  13. TSTRBOY2004
    ^^^ knowing what he wants < not knowing what he wants :)
  14. carl
    we gotta gooooo
    yea i'm marginally indecisive over this. I'll probably stick with the the JIC because I don't want to get this and then a midpipe which means added expense that could be better used on other stuff
  15. bikerwriter
    St. Louis Park
    You said this "season" is all about suspension, and then you ask for us to vote on how pretty a rectangular exhaust looks. I was pointing out the irony as a joke. I think your sense of humor < zero.
    I doubt anybody here has a PhD in aerodynamics, thermodynamics, fluids, etc. You can't do a flow calculation even though you know the difference in diameter of the different pipes because you don't know the exact cfm of the turbo on your car at peak horsepower. Any nobody knows the flow rates of the different mufflers. So we're all just guessing.
    But I am a scientific person. So to answer the question you posted at the top of the thread, I will chip in $10 towards a second set of pulls on a dyno day for you to measure 3" versus 2.36" exhausts.
  16. carl
    we gotta gooooo
    hey sorry about that, i'm just very crabby because i'm working on all that stuff you just mentioned - particularily heat transfer and fluid flow. if i had more time i probably could run some fairly accurate simulations on ANSYS but I would need some egt and flow rate data, also convective coefficients for the exhaust and air
  17. TSTRBOY2004
    ......... and they all said...... View attachment 2868 View attachment 2869 View attachment 2870 View attachment 2871 ......huh?!!?:eek3:
  18. bikerwriter
    St. Louis Park
    Easily understood. :) I bet you even had a Thursday morning meeting that was a complete waste of time and that prevented you from doing real work.
  19. carl
    we gotta gooooo
    yea that was called philosophy :laugh:
    but then i had heat transfer lab which is pretty awesome actually
  20. shineynitelite
    st. paul
    /thread
  21. piddster
    Boostonia
    A muffler I picked up on ebay for my original exhaust plan had a three inch inlet and necked down to a 2.5. I thought it was pretty jank but for $45 what do you expect. So I asked one of my profs who was the fluids geek and he said the perforations in a straight through muffler are more of a restriction than the change in diameter, granted the change is smooth.
    food for thought
  22. carl
    we gotta gooooo
    you have a girl's name
    /thread
    (are we installing your exhaust this weekend?)
  23. shineynitelite
    st. paul
    /lolz.
    i dont think so, i think kevin finally might have time :laugh: (now that i said this, he prolly wont :emo: )
  24. ShortytheFirefighter
    And without those perforations, it's a pipe and not a muffler. So, what's more restricting? A baffled muffler or a straight through muffler? And now we're back to the beginning of the thread...
  25. bikerwriter
    St. Louis Park
    That's why I'd offer $10 to see the axleback swapped out in the parking lot on dyno day with a new pipe given three pulls. The layman's way of measuring...
    "Boy, them there engineers sure do make fine tools." :laugh:
  26. carl
    we gotta gooooo
    that's why i posted hoping someone had real world results. figuring out an accurate simulation would take too much time
  27. shineynitelite
    st. paul
    they wouldnt let you do it, they'd have to strap, then unstrap, and then restrap
  28. WRX1
    Over there
    Well, I know back in the day, Riftswrx did some testing with his car. 02 wrx, 4eat, built 2.5 (might have been the 2.2) and he was running right around the 380 mark (so about 420 in a 5/6 speed) at the wheels. Between his txs magnaflow (2.5 inch pipe) and his stock muffler was about 20-25 whp. Like I said before, until you are up around the 400whp mark, I don't think you will notice a difference between a 2.5 and a 3". You want to keep the air volecity high and with a exhaust that tapers a bit at the end will help that out.
  29. piddster
    Boostonia
    I didn't say you shouldn't have the perforations. All I said is the they have more of an effect than the neck down in diameter, which is minimal. Please don't put words into my mouth :biggthumpup:
    Compressible fluids are a real biatch to simulate.
  30. bummpy
    bummpy New Member
    nordeast
    I've done it before. But even with FEA software it takes like 10-15min to iterate. And that's with just a 2D model of a strait pipe and laminar flow.
    It's fun and academic to model fluid flow, but anyone running a txs stealth-back with their stock muffler want to chime in on what their numbers are at stage 2? Can you even run stage 2?
    I'm thinking I want to go that route. Although zak also gave me a ride in his cobb tbe stage 2, and that was quite sex as well.
  31. carl
    we gotta gooooo
    ANSYS is pretty good for modeling most anything lol. the main issue is coming up with all the constants and rates to input
  32. bummpy
    bummpy New Member
    nordeast
    Bingo!
    You telling me you want to crawl all over the place trying to inaccurately measure your entire exhaust geometry. Draw it up in cad, incorrectly guess at your boundary conditions, and incorrectly guess your fluid condions. To just in the end not even have enough nodes to even model it 2D. And then in the end, your simplified, not enough node havin' model ends up taking 4 hours to iterate.
    No thanks!
    Dyno pulls, swap, repeat.
    Even though I wanted to do that anyway when I was in school, you know, for fun. :roll:
  33. ShortytheFirefighter
    Not trying to put words in your mouth ;) Just thought I'd throw it out there.
  34. piddster
    Boostonia
    word. :cheers:
  35. wall of tvs
    dream ftw
    Well here's a little test I did right after I got my '06. Stock everything with the exception of the addition of a Prodrive axelback.
  36. tangledupinblu
    MNBugeyeMafia#001
    So she topped out at about 190hp?
  37. wall of tvs
    dream ftw
    Yeah. I just looked at the logs from these two pulls, and they were taken about 3 hours apart. Intake temps were about 2* cooler on the 2nd pull since it was later in the evening.
  38. bikerwriter
    St. Louis Park
    I'd like to know how he got such a perfect overlay on his graphs. I never get the same shape on mine. :(
    But to a previous question, I am running a TXS Stealthback with the stock muffler and a "Stage II" tune on my 2.0 Saabaru. Actually, I don't know what stage Tom would call it, but it's pretty strong. My MAF readings are 238. Consider that way back in the day with a Cobb Stage 2 map, we logged 188. But maybe I should order a Prodrive and then compare MAF readings.
    I still want to see 20 psi on the stock turbo...
  39. tangledupinblu
    MNBugeyeMafia#001
    Can't wait to see the upcoming numbers from your custom map!:p
  40. wall of tvs
    dream ftw
    I make all my road dyno pulls on the exact same stretch of road in the exact same spot.
    And with my current stage 1 tune, my road plots are showing ~260wtq. w00t.
  41. bikerwriter
    St. Louis Park
    There's too much traffic on the roads around here for me to stick with one spot. The one place I used to be able to get a good pull has been jammed with traffic the last three times.
