Stock Items From a 2003 Forester
Discussion in 'For Sale : Car Parts' started by Shancaldazar, Oct 28, 2012.
  1. Shancaldazar
    All parts are in good, working condition! The reason for removal of these parts was because I upgraded to better parts!
    I have some of the factory stock bushings for sale first off. All of them are in good condition, and still have plenty of life left in them. Both the engine and transmission mounts show a small amount of flex by hand (typical of the stock pieces), but aren't overally soft. Great for back to stock, or replacing your mounts with 200,000 Miles on them! Mileage is roughly 80,000 on these.
    (2) Stock Engine Mounts (comes with metal mounting plates)-$10 Each or $15 for both + Shipping SOLD
    Stock 5-speed Transmission Mount- $10+ShippingSOLD
    Stock Transmission Crossmember bushings-$5+ shipping or FREE with Transmission Mount!
    Stock Pitch Stop Mount-$10
    (2) Subaru 20MM Sway Bar Bushings-$5 for both+ Shipping
    Next is the mounting equipment for the forester rear sway bar (stock). And the stock forester Sway bars.
    (2) Stock Metal Brackets-$10+ Shipping
    (2) Bushing U-Brackets-$10+ Shipping
    17MM Rear Sway Bar-$40+Shipping
    20MM Front Sway Bar-$40+ Shipping
    Rear Sway Bar still has factory paint markings on it!
    Also A stock 5-speed shift knob, with a small amount of wear on the surface of it. Great for back to stock again.
    Stock 5-speed Shift Knob-$10+Shipping
    Stock 5-speed shifter lever-$25+
    And Finally I have some brake stuff for sale! Once again, all of it is in working order and was taken off because I upgraded to LGT brakes and STI BB/MC. The driver's side rear caliper only has about 6,000 Miles on it, as it is a remanufactured one that I bought after I found the dealership that previously serviced the vehicle had broken the bleeder screw in the old caliper. I cleaned and lubed the caliper slide pins with sylglide, as well as replaced a torn accordion boot. They both slide freely.
    Rear Calipers Left and Right-$45 each, or $75 for the pair+Shipping (come with free brake pads, 35% life left, and also 3 extra accordion boots)
    (2) Rear Rotors-$15 Each or $20 for the pair+shipping
    (2) Front Brake Lines (stock rubber ones)-$10 Each or $15 for the pair+shipping
    Stock Brake Booster- $50+Shipping
    Stock Brake Master (bore size of 1, upgrade for you legacy Guys) Cylinder-$30+shipping
    Free With either of the calipers-extra accordion boots.
    Let me know! I will of course combine items to try to keep shipping as low as possible!
  2. Shancaldazar
    I prefer you pick up over shipping, and can arrange to meet up.
  3. SubieDave
    SubieDave Well-Known Member
    where are you located?
  4. Shancaldazar
    Plymouth.
  5. SubieDave
    I want to grab a few things, but I cant make it out this week. Do you know by chance if those brake lines are a direct swap for a 99 legacy brighton?
  6. Shancaldazar
    Not sure on how the brake lines are mounted on the legacy, but they definitely will be long enough. The forester ones bolt into the strut body, with a single bolt. Send me a PM of what you want, and when you would be able to pick it up.
    Also Motor and Main transmission mounts are pending sale.....
  7. Shancaldazar
    Bump! All items still for sale. Had several buyers back out on several items...
  8. Shancaldazar
    Engine and Transmission Mounts Sold!
  9. Shancaldazar
