Stock Steering Wheel
Discussion in 'For Sale : Car Parts' started by jyo, Sep 14, 2005.
  1. jyo
    jyo New Member
    I need help! I just got a 99 RS and there is an aftermarket steering wheel on it. I have the stock one, but the problem is that the clips that connect the stock steering wheel is cut. Where and how can I fix it?
  2. ShortytheFirefighter
    I've got a stock 02 RS steering wheel (with airbag) and I've got a couple of 02 WRX MOMO steering rims in ok shape. You'd need to find an airbag for the MOMO rims. What connectors are cut, the ones in the steering wheel for the cruise control. If the connector that leads out of the steering roll connector (They're the yellow airbag ones) is cut then you'll need a new roll connector. Those can be rather pricey. Just let me know and I can price one out for you, and let me know if you're interested in the steering wheel. Thanks!
  3. jyo
    jyo New Member
    I'll look at it again. Can't the stock air bag fit on the MOMO rim or is too big?
  4. jyo
    jyo New Member
    Just noticed Brian, My car was just there, the blue 99 2.5 rs with the carbon fiber hood. I met Brett and you might have seen me yesterday when I came to pick it up around 6, but Man, things sure got messed up around there.
  5. ShortytheFirefighter
    It's Jerry, right? I remember meeting you. I'll check to see if the stock airbag I have would fit a MOMO rim. If it will I'll show you the two I have and we can go from there. I want to make sure they didn't cut the wiring on the roll connector, because if they did then you'll need a new one. Give me a call or stop in when you get a chance, I'll be here all day Saturday from 8-4. Have a good one!
  6. jyo
    jyo New Member
    Yeah, sounds good I'll stop by some time Sat. and let you have a look at it. Cool, sounds like a plan.
  7. jyo
    jyo New Member
    Brian, it got it installed and the airbag is set and good to go. Thanks alot. Forgot about your MOMO Steering wheel! the abs light is still on and the turn signals won't automatically go back to neutral once you turn. Any ideas? how much were the sipped tires?
  8. ShortytheFirefighter
    No worries, stop in any time and you can take your pick. We'll also check to see if the airbags are compatible. I'll ask about the turn signals. The ABS light might need to have a code cleared, I'll find out what might be involved with that one. I've got to look up the pricing, but for 17's the Hakka RSI's are in the 800 dollar range. I'll get the exact price for you on Tuesday. Thanks!
  9. jyo
    jyo New Member
    yeah, i was looking for some allseason tires for the 17s and they're not cheap. but can you help check on the price with installation and mounting and ABS.
    thx
  10. ShortytheFirefighter
    What size 17's do you need?
  11. jyo
    jyo New Member
