Stock turbo limits???
Discussion in 'Modifications And Maintenance' started by bikerwriter, Jan 13, 2007.
  1. bikerwriter
    bikerwriter Well-Known Member
    St. Louis Park
    I was talking to Tom (walloftvs) earlier tonight and I was curious what the "safe" upper boost limit was for the stock wrx turbo, and how one can "safely" achieve it. Both terms are relative, I know.
    Does anybody here know what boost limits the stock turbo can handle, and what is required to support it?
    For example, I've examined the logs I took last night and can see that at WOT I am running over 100% on my stock injectors with my Stage II map. So it would appear that before trying to get more power out, one would have to upgrade the injectors. But if you mod the stockers, do you need to upgrade the fuel pump to keep the fuel pressure up?
  2. Iroc-Z
    Iroc-Z Well-Known Member
    New Germany, MN
    I would bet with injectors and a pump there is more to be had out of the stock turbo. I think there was a guy on nasioc who was going that route.
  3. bikerwriter
    St. Louis Park
    I found a thread by ride5000 on Nasioc and he has run over 20psi on the stock turbo. I didn't see him upgrade his injectors, although maybe I missed it. I think he got around it by upgrading his fuel pump and installing an adjustable fuel pressure regulator though.
    I saw a post stating that the WRX TMIC falls off after 300hp. I suppose that is the next bottleneck?
  4. w_o_t_boy
    w_o_t_boy Well-Known Member
    Seattle
    I think your TD04 will just wear out unusually fast if you start trying to run a lot of boost through it. You can always buy another one, though.
    Turn your target boost down until your injectors are running at about 95% at those higher RPM's.
  5. bikerwriter
    St. Louis Park
    Exactly! :biggrin:
    Seriously, Ride5000 and some of the others said they had 30k+ miles running that boost. I saw a sample of the target boosts and they ramped up the boost in the midrange before turning it back down. Between 20 and 21 psi target at 3500, then down.
    Now what fun would that be?
    That said, I know running 100% for extended periods is bad. And I'm running 100% by 5700, and all the way to redline. :eek4:
    The guys running higher boost on the stock turbo aren't maxing out their injectors according to their logs, which leads me back to upgraded injectors and fuel system.
  6. Iroc-Z
    New Germany, MN
    True but alot of people run 20 psi out of IHI turbos for a while. I don't think the turbos life is going to be shortened that much.
  7. wall of tvs
    dream ftw
    Or they are running leaner AFR targets. I have you running really rich up high. Plus, this is your initial revision and I haven't adjusted anything yet.
    Once all is said and done, you can pick your target boost up to around 4000ish rpms. From there with a 10.8:1 fuel target the max the injectors can run is about 16.5psi @ 4500rpm and then needs to taper down to 12psi by redline.
  8. wall of tvs
    dream ftw
    No it won't, unless you are maxing the crap out of it, ie, trying to run 17psi @ redline all the time.
    But if that is the case and you don't have larger injectors, the life of the turbo is the last thing to worry about, lol.
  9. bikerwriter
    St. Louis Park
    Rich is good. We like rich. No chance for a "blowing flames and you aren't making any more power".
  10. bikerwriter
    St. Louis Park
    I am amazed to see the stockers are maxed out with a strong Stage 2 map. How depressing. :emo:
  11. wall of tvs
    dream ftw
    Wrong.
  12. bikerwriter
    St. Louis Park
    No, I just saw that on Nasioc and had a good laugh. I just had to import it here.
    And your fingerprints are all over that thread. :hsugh:
  13. wall of tvs
    dream ftw
    Oh. lol.
    Link?
  14. Justin
    Justin Well-Known Member
    St. Paul, MN
    i thought ride and those guys were spraying meth to get 20psi out of a td04
  15. wall of tvs
    dream ftw
    Ride is running a vf23 turbo.
  16. Justin
    St. Paul, MN
    maybe it wasnt ride. there is/was a group of guys on nasioc blowing a td04 at 20-21psi with meth
  17. bikerwriter
    St. Louis Park
    Here the start of the thread. It all started with a compressor map for the stock turbo. Go figure.
    http://forums.nasioc.com/forums/showthread.php?t=988825&page=1
    I checked out Ride's website and yes, he has upgraded his turbo along with some other stuff, but he did turn the stocker up to "11" earlier in his career.
    Page 4 has links to more "crank up the stocker" threads, and if you look carefully, you'll see posts by our own wotvs. :cheers2:
  18. wall of tvs
    dream ftw
    Yeah, that was one of the very few good threads I've stumbled across on nazicock.
  19. bikerwriter
    St. Louis Park
    :laugh:
    I can't stop laughing!!!!!!!!!!!!!!!!!!!!!!!!!
  20. esperunit
    esperunit Well-Known Member
    Paris, 7eme Arrt.
