Been looking at gauges and I came across these. No clue if they're any good or not, anyone have experience? looking for feedback.... I like the Imperial X-line with amber since I'll eventually swap out my cluster for an sti. hopefully jdm. I'm looking at the egt and boost for starters. Probably mount those two on the steering column, the rest will eventually go on the dash. another question regarding the EGT. The gauges don't typically come with the wiring and sensor itself, or do they? Here's a quick video here's the website http://www.striracing-usa.com/pro_x_e.htm
That video has the Perrin gauge mount I want ... ps those gauges are hot I wish they came in green to match my car.
I've heard some positive things about these on Nabisco. The ProSport gauges are pretty renowned, but don't look as much like Defi's like the STRI gauges do.
I haven't heard anything about those gauges, they look good. My Maddad EGT gauge came with a temp probe and all the wiring needed for install. I'm pretty sure that's standard. What made you think it wouldn't come with a temp probe?
Ooh, those would fit the startup sweep on the LGT if I could tweak them to match timing. Too bad I still haven't found a gauge mounting setup I like.
