stripped aluminum holes
Discussion in 'Modifications And Maintenance' started by AspitFire, Mar 20, 2006.
  1. AspitFire
    Ok guys, for those of you who were at jasons on saturday, you alread know the situation, for those that werent i will bring you up to speed. The two holes on this used intercooler i got are stripped where the bov/bpv goes. Now everyone at jasons said i should try heli coils, but i cant seem to get them to work, so i retapped and threaded the existing holes from 8mm 1.25 thread to 10mm 1.50 thread, still strips it self out. any ideas? or should i just tell who i got it from i want my money back?
  2. phi11
    what about welding some aluminum nuts to it?
  3. AspitFire
    i dont weld, and wouldnt that make everything NOT flush with the intercooler?
  4. phi11
    I do. ya, that wouldn't work.
    okay, what about an aluminum stud welded in the striped holes?
  5. Justin
    Justin Well-Known Member
    did the guy sell it to you with stripped holes?!?!
    didnt you get it from a guy on here?
  6. AspitFire
    possibly, then retap the hole, but i dont want to uninstall this again, install to stock one, then try to reinstall again, this thing is such a pain to take in and out, i have so many band aids on my hands today from intstalling and uninstalling it yesterday
  7. AspitFire
    No, he didnt tell me they were stripped. Yea, i got it from 16gsx on here, i will call him later and see what he says, he told me when i bought it, if i didnt like it of if it didnt fit he would buy it back from me, so well see. Hes a good guy i dont think he would scam me.
  8. AWDimprezaL
    drill the holes all the way through and put a nut on the other side (use longer bolts)
  9. AspitFire
    i could do that but would be next to impossible to install it with the bpv attached to the tmic before install, you either cant attach it to the stcok bpv tube or you cant get the turbo hose attached or the throttle body hose attached .
    If i attach the bov after i install the intercooler, i dont know how i would get the nut around the back of the mount on either side, the opening is tiny.
  10. slavboy1
    slavboy1 New Member
    What about drilling the holes out larger so they're clean and then helicoiling them or simply just tapping them?
  11. phi11
    we tryed a heatercoil already.lol
    its too big.
  12. slavboy1
    slavboy1 New Member
    aaaah gotcha sorry haha
  13. TSTRBOY2004
  14. Dynapar
    how much room do you have to deal with here? is it possible to counter drill an area big enough so that you can put a nut in and haveit sit flush? is so you could JB Weld the nut on there and then use a matching bolt.
  15. subytek
    subytek Well-Known Member
    Yeah "heater coil".
  16. AspitFire
    i guess somthing like that might work.
  17. AspitFire
    damn idiots at checker.
  18. Snuff
    Online
    Snuff Guest
    Braze the holes shut, drill, and retap.
  19. AWDimprezaL
    have someone weld an aftermarket BOV on, that way you wont need a different bov down the road, (for boost issues)
  20. AspitFire
    live near andover???
  21. driftin240
    driftin240 Well-Known Member
    Josh, heli-coil the hole and do it right. Any welding done is basically permanent without a ton more work. The actual size is a 10mm X 1.25 pitch....not sure on the factory length of the bolts. I'll check the price of a heli coil kit for ya. edit: I can get you a kit from napa but their not cheap! $55.00
  22. Todd
    Todd The Originator Staff Member
    How about epoxying studs into the holes?
    Mock it up while the epoxy is setting up.
  23. AWDimprezaL
    j/b weld some studs into the I/C itself, then use nuts instead of bolts!!!! wewt!!! or have the studs welded in! god damn im smart :lol:
