Subaru AWD tranies
Discussion in 'General Subaru Discussion' started by Dynapar, May 10, 2005.
  1. Dynapar
    i have a question regarding the power distribution in subaru tranies. first off what is the power distribution in an automatic trany. (i dont know what model trany i have,ita a 95 awd auto, so i dont think its a 4EAT, since its so old) anywaay i have heard the following from different sources.
    F / R
    60 / 40
    50 / 50
    40 / 60
    also whats the distribution for a standard 5 speed tranny?
    thanks
  2. kongzilla
    kongzilla Well-Known Member
    I believe its 40f and 60r
  3. AWDimprezaL
    standard 5 speed is 5050 autos are 60F 40R
  4. Dynapar
    there are two different answers here, which one is correct?
  5. Grimm
    Grimm New Member
    <blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Originally posted by Dynapar
    both, and neither.
    Which model, and transmision.
    STi's can get up to 35%/65% in both directions.
    Driver Controlled Center Differential
    Exclusive to the WRX STi, Driver Controlled Center Differential (DCCD) All-Wheel Drive, featuring both manual and automatic modes, uses an electronically (DCCD) All-Wheel Drive managed multi-plate transfer clutch in conjunction with a planetary gear-type center differential to control power distribution between the front and rear
    wheels. Normally, DCCD splits power 35% front and 65% rear. DCCD also features a helical-type limited-slip front differential and mechanical limited-slip rear differential.
    WRX, Automatic
    Variable Torque Distribution (VTD)
    WRX models equipped with 4-speed automatic transmission utilize an electronically controlled variable transfer clutch in conjunction with a planetary-type
    All-Wheel Drive center differential. Rear wheel-biased torque distribution normally configured at 45/55-split front-to-rear. VTD also features a viscous-type limited-slip
    WRX Manual
    Continuous All-Wheel Drive Models equipped with 5-speed manual transmission utilize a viscous-type locking center differential with torque distribution configured at a 50/50-split
    front-to-rear. WRX models also feature a viscous-type limited-slip rear differential.
    So on so forth
  6. Zola
    Zola Well-Known Member
    The answer, as best I can tell is: it depends.
    In 1 and 2, the auto apparently has a 50/50 split. In 3 and D you get a continuously varying split depending on wheelspin, not a locked 60/40 or anything like that. If you are accelerating it's more like 50/50, but cruising at highway speeds you are essentially FWD.
    The VTD AWD system on the H6's is a 45/55 split I think.
    I found it on the internet so it must be true.
  7. Deride
    Isn't the WRX manual 3.9 front, 1.1 center and 3.545 rear? giving it more power to the rear wheels? auto WRX 4.111 front and 4.111 rear like my 02 RS but with a limited slip rear? gotta love my 2 wheel wonder 2.5 RS. Can't wait to get money for a limited slip rear, I hated this last winter... hehe
  8. AWDimprezaL
    i thought RSs got lsd...because XS foresters did, and there is nothing special about an XS forester
  9. Deride
    Only 00 and 01 RS's have rear LSD.
