Subaru Turbo cool down not necessary. 2002 - 2015 models.
Discussion in 'Modifications And Maintenance' started by drac77, Sep 8, 2014.
  1. drac77
    drac77 Well-Known Member
    I got this from another forum that I am a member of and the source is Infamous Performance and Tuning out of CA. Who source it from a Master Subaru Technician and is a copy paste from an internal memo. That being said I am sharing for feedback and pretty sure it only applies to stock configurations.
    Subaru Turbo Cool Down Procedure
    It is not necessary to perform a “cool
    down/idling” procedure on Subaru
    WRX/STi/LGT turbo models, as was recommended
    with past turbo models. The
    current 2.0/2.5 liter turbo engine has a far
    greater cooling capacity and, coupled
    with technology advances, makes this
    practice no longer necessary. This
    explains why information about a cool
    down is not included in the
    Owner’s Manuals.
    The heat contained in the turbocharger
    begins to vaporize the coolant at the
    turbocharger after the engine is
    stopped. This hot vapor then enters the
    coolant reservoir tank, which is the
    highest point of the coolant system. At
    the same time the vapor exits the turbocharger,
    coolant supplied from the
    right bank cylinder head flows into the
    turbo. This action reduces the turbocharger
    temperature. This process
    will continue until the vaporizing
    action in the turbocharger has stopped
    or cooled down.
  2. idget
    This is accurate. For example, the stock turbos on my 911 aren't water cooled (just oil cooled), so the owners manual suggests letting it idle for 2 minutes after every drive. Failing to do so results in some smoke on start-up from the coked oil. Not the end of the world, but something that comes up constantly in forums "zomg my kar iz smoking. Did it died?"
    joebush44, drac77 and BroCo like this.
  3. Todd
    Todd The Originator Staff Member
    To me there is a big difference between cool down and spin down.
    Subaru has always done a good job of using water cooled turbos and convection to cool the turbo housing after shut down. That cooling doesn't release you from good shutdown procedures. Modern oil also does a better job on NOT breaking down under extreme heat and pressure.
    Bottom line: Don't shut your engine off right after zooming the turbo.
    yuseforester, CarpalTomO and idget like this.
