Summer wheels/tires, Steelies, Modded Injectors, Roof Rack parts
Discussion in 'For Sale : Car Parts' started by xveganxcowboyx, Nov 9, 2011.
  1. xveganxcowboyx
    17x17 5x100 MB Mesh Wheels with Hankook Ventus V12 Evo tires. 225/45/17. I believe the offset is 43 or something very close to that. I put a few thousand miles on this setup at the most. One wheel has another off brand performance tire on it which was a temporary spare, but I have a replacement Hankook for that wheel. I can have it swapped first or you can do it and keep the spare off brand tire. Asking $600/obo.
    14" 5x100 steelies. These are off a Matrix I believe so i will have to check the center bore. Toyotas are typically 54.1, but I think these were replacements so they may have a larger center bore. Someone might be able to use them for winter wheels. Asking $50. *Note, I am pulling the tires off these in the next couple days. The wheels can not be sold before then.
    Modified 2002 WRX injectors. Modding done by Fuji. Cleaned and flow tested at Ravenworks. I do not remember the flow (I want to say ~905cc since their tester usually reads a little high, but maybe it was 805cc). Either way that will be dealt with in tuning. All were under 1% variance. Run for probably 1,500 or 2,000 miles. Asking $160/obo
    This is pretty much a space saver for when I get home and look at the rack components. As usual I am posting from work when I am short on details. I have some take off stuff from a Legacy Wagon factory rack. I think it's a bike or ski rack. Can't remember for sure. I will fill in details and price in another post later.
  2. dmoo
    dmoo Well-Known Member
    did you get any type of flowchart printed out for the injectors?
  3. xveganxcowboyx
    They gave me a sheet with the before and after flow numbers, but I unfortunately have no idea where it is.
  4. xveganxcowboyx
    The tires have between 7 and 8/32" outer and inner tread depth. New was 10/32".
    The steelies seem to measure 56mm for the centerbore. The caliper doesn't quite fit inside the wheel, but got close enough for a pretty good guess at 56.
    The roof rack is actually a ski/snowboard rack. The mounts are for round cross bars, but other mounts can be bought from Subaru. Still best offer on this since I do not know what it/they are worth.
  5. xveganxcowboyx
    The summer wheels and tires are no longer for sale. The rest still is. I would be willing to trade for 04 STI Struts, Springs or Rear top hats, a 20mm or larger rear sway bar or some 15" snow tires. My new Forester needs to be upgraded. :)
