Sunroof Won't Close
Discussion in 'General Subaru Discussion' started by lmlght14, Mar 15, 2012.
  1. lmlght14
    lmlght14 Active Member
    The sunroof on my 08 LGT won't close. When I try to close the sunroof, the glass gets almost closed then moves back to the half open position. I checked the area and I can't find anything in the way. I read the owners manual and it sounds like the anti-entrapment function is malfunctioning. Has anyone experienced this or know how I can get it closed?
  2. Nater
    Nater Member
    there is a manual way to close it I bet. There should be a cover someplace were the mechanism is, my jetta had one and there was a allen wrench to use if it happens. This is a shot in the dark lol.
  3. john
    john Well-Known Member
    Are you, by chance, still under warranty?
  4. lmlght14
    No I'm not.
  5. tangledupinblu
    Maybe try to reset everything by disconnecting the battery quick? Disconnect battery, get in car and push the brake pedal to the floor, reconnect the battery...then try to close it again.
