Swapped 2000 OBS with 07wrx, 290whp, 311wtq Vf48
Discussion in 'FS: Cars, Motorcycles, Boats' started by mke723, Oct 5, 2015.
  1. mke723
    mke723 Well-Known Member
    2000 Subaru Impreza Outback Sport
    Clean Title
    Aspen White 2-tone
    Mileage (approximate): 150xxx on body, 98xxx on engine, cluster is from an RS and says 2xx,xxx
    MAJOR MODIFICATIONS:
    • EJ255 out of a 2007 WRX
    • iWire Merged Harness #125
    • VF48 turbo @ 19 psi running hybrid boost control (Grimmspeed 3 port EBC/Hallman ProRX MBC)
    • Process West Top Mount Intercooler w/splitter
    • 5 speed transmission & rear differential out of 2007 WRX
    • 4 pot front brakes / 2 pot rear brakes out of 2007 WRX
    • KYB AGX Adjustable Struts with V7 STi RA Springs
    • Tial 44mm External Wastegate with atmospheric dump (Nice and loud)
    • HKS Catless Downpipe with 3” Maddad Whisper Dual Tip Exhaust (Nice and quiet)
    OTHER MODIFICATIONS:
    Interior:
    • RS Gauge Cluster
    • Front/Rear Seats out of 2007 WRX Wagon
    • WC Lathe Werks Custom Co-polymer Shift Knob with brass insert and 3" aluminum extension
    • RS Black Lower/Center Dash
    • Maddad Ultra Clarity 52mm Gauges (Oil Pressure, Boost, EGT)
    • Kenwood Stereo Deck w/Aux input
    • RS Floormats
    Exterior:
    • JDM Taillights
    • MRT STi Upper Wing
    • Clear Corners
    • IXIZ Hood Dampers
    • Rallyarmor UR Mudflaps
    • Hella Supertones
    • Painted Engine Bay Black
    Engine:
    • Big K&N Filter w/heat shield and pre-filter
    • Turbo Blanket, not on it, but have 1
    • Carbon Fiber Accessory Belt Cover
    • APS MAF Housing
    • TGV Deletes
    • Air Pump Delete
    • TurboXS EWG Up-pipe
    • GrimmSpeeed AOS
    • Walbro 255lph Fuel Pump
    • Borla Hush exhaust
    Suspension/Drivetrain/Brakes:
    • Silver 5 Spoke RS Wheels
    • Continental control contact 205/55/16, new June 2015 less than 5k on them
    • 20mm FHI Rear Sway Bar
    • Whiteline Rear Sway Bar Endlinks
    • 24mm Whiteline Front Sway Bar
    • 07 WRX Steering Rack
    • 07 WRX Front Crossmember (with shimmed control arms)
    • Turn In Concepts Rear Trailing Arm Bushings
    • Rear Quick Release Strut Brace
    • Brake Master Cylinder Brace
    • 07 WRX Brake Master Cylinder/Booster
    • Stainless Brake/Clutch lines
    IMPORTANT NOTES:
    • The open source tune, although conservative, is for 93 octane
    • Has launch control and flat foot shifting @ 4500rpm for both
    • AVCS is fully functional
    • Cruise Control is fully functional
    • A/C works, but needs a recharge about once per summer
    • This car will pass OBD emissions testing, it doesn’t have any CEL’s
    • Battery was replaced in spring 2013
    • Oil Changed using Rotella T6 Full Synthetic
    • Trans/Rear Diff Oil is Redline 75W-90
    • New windshield replaced 4/18/2014
    $11,500 OBO
    EricS likes this.
  2. Mitchum
    Mitchum Well-Known Member
    So effing cool!!! Glws!
  3. tangledupinblu
    Any "full car" pics? Interested in seeing this sleeper in its entirety.
    GLWS!
    tehfuzz likes this.
  4. mke723
    I can after work.
  5. DoughtCom
    DoughtCom Well-Known Member
    I've seen this car in person and driven it! It's a very solid car with good mods, the swap looked pretty clean too. Other than the rust this is a pretty clean chassis.
    mke723 likes this.
  6. mke723
    Full car shots
  7. mke723
    Pics
  8. mke723
    Price drop $10500
  9. mke723
    No one is intrested? Is my price too high?
  10. SlowSC
    SlowSC Well-Known Member
  11. mke723
    Also have a black 98 RS front bumper with Fog lights and all the vents that I have not got around to painting that was to go on this.
    It's already on a beam.
  12. mke723
    Price drop for MNsubaru $9000
  13. EricS
    EricS Nooberator
    Lots of parts and labor for that price! Would make for a sweet rallyX/iceX car, nice torquey power curve.
    DoughtCom and Deathly like this.
  14. mke723
    In starting to think nobody would want this if it was free and had $20 in the cup holder...
  15. jmyhre05
    jmyhre05 Well-Known Member
    Nov-Jan are the 3 hardest months to sell a car and this is something people can't get a loan for so it's going to take time.
    ScoobySnack likes this.
