sway bar compatability
Discussion in 'Modifications And Maintenance' started by silver03, Jan 22, 2008.
  1. silver03
    MN Bugeye Mafia #300
    03 sedan rear sway fit 04 sedan?
  2. Moleness
    At work or in the garage
    Pretty sure. Someone confirm???
  3. Dynapar
    Orono, MN
    should fit no problem, as long as both are WRX. STis have a diffrent rear sway bar which i think you need new endlinks to use (?).
    is it a early model 03? the late model 03s have the same size (17mm) bar as the 04+. the 02s are guaranteed to have a larger bar (20mm).
  4. Justin
    Justin Well-Known Member
    St. Paul, MN
    sti rear sway fit my 96 impreza L fine w/ wrx style endlinks
  5. Dynapar
    Orono, MN
    ^ interesting it didnt line up quite right on lilred's GC. it fit but not exactly the way it should.
  6. Justin
    St. Paul, MN
    the only thing i had to do is grind down the bushing that goes around the bar and to the bracket on the mount. the newer models have a slightly different metal bracket that goes into the sway bar mount.
