I just recently installed my superpro swaybar on 2013 WRX. I don't know if I put the endlinks right. If you can see the picture that the top bushing doesn't look right to me. Need some opinions. Thanks
If the car is jacked up and suspension at full droop you will have deflection but it should split evenly between upper and lower endlink mounting points... I would drive it around to settle the suspension and check it while on the ground at ride height
