sway bar questions
Discussion in 'Modifications And Maintenance' started by COBBsoobyStage1, Jun 26, 2007.
  1. COBBsoobyStage1
    COBBsoobyStage1 New Member
    First question; if you got'em what do ya got and how do you like 'em.
    Secondly; since I just got my springs installed, should I wait until I get the swaybars to get the alignment?
    3rdly; anyone able to help me w/ the install?
  2. esperunit
    esperunit Well-Known Member
    21-22mm front, 22mm adjustable rear and you'll be fine for the street and a bit beyond. will not affect the alignment at all. With air tools and a lift it took me about 20 mins to do the front bar, but it requires removing the front subframe so you need to understand what that entails. I wouldn't want to do it not on a lift, thats for sure.
    rear bar can be installed in a driveway as long as you have ramps and racthets. its not very hard.
  3. Shane86
    Shane86 Well-Known Member
    Pfts... wuss.
    i installed my rear bar with the car sitting on the ground.
    it's DEAD nuts simple. i just popped a couple of exhaust hangers to get the clearance needed to feed the bar in.
  4. Deride
    I put my rear bar in with the car on the ground. It's not that difficult. Although the stupid gas tank emissions canister thing was in the way of one bolt.
  5. COBBsoobyStage1
    so you guys only have the rear sway bar then?
  6. TSTRBOY2004
    thats all I have on mine... perrin with perrin end links...
  7. Bullwinkle
    Same as esperunit, I have both. I would highly recommend a front bar, as it improves turn in and body roll even more dramatically then a rear bar. 22mm for both is fine for street use. Although, if I had to do it again, I would do 24mm fsb, and 22mm rsb.
    I did my front on ramps on my driveway. While it would've been easier with a lift, it really wasn't that hard, as long as you have a impact wrench. The rear is a piece of cake.
  8. COBBsoobyStage1
    nice. so being a cobb whore, what duhya think about their 25mms? Hollow, but too fat?
