Techy101's Spring Cleaning Garage Sale
Discussion in 'For Sale : Car Parts' started by techy101, Jun 5, 2006.
  1. techy101
    techy101 Well-Known Member
    Techy101's Spring Cleaning Garage Sale (Prices Dropped)
    Hey all. So I'm trying to scrap up money for my tranny mods, and it seemed like a good time to put some things up for sale that I've got laying around.
    Here's a list of the items, pictures (if I have one) and descriptions below.
    -Alpine SPS-171A 6.5" 2 way Component Speakers $125 (Price Dropped)
    -PIAA 2192 25 degree accessory Driving Lights $150 (Price Dropped)
    -Toshiba 14AF44 14" flat-tube TV SOLD
    -Clarion EQS746 1/2 din 7 band EQ $75 (Price Dropped)
    -Alpine SPS-171A 2 Way Component Speakers.
    These are slightly used, were installed professionally (by a real car stereo shop (http://www.ultimate-audio.com) not a place like Best Buy) in my old Forester X. I took them out when I got rid of that car, and they've been sitting on a shelf. In perfect working order. They sound great, and the crossovers are fairly small, for easy placement.
    Sale includes:
    2 midbass drivers
    2 Midbass grills
    2 tweeters
    2 crossovers
    a bunch of various mounting cups for the tweeters
    Here are specs from Alpine's website:
    SPECIFICATIONS
    Power Handling
    • • Power Handling Capacity (Peak) : 250W
    • • Power Handling Capacity (RMS) : 50W
    General
    • • Crossover Size (in) : 4-3/4" x 1-3/8" x 2-9/16"
    • • Crossover Size (mm) : 120mm x 35mm x 65mm
    • • Frequency Response : 35Hz - 30kHz
    • • Impedance (Nominal) : 4 ohm
    • • Sensitivity : 90 dB/W/m
    • • Tweeter Height (in) : 1-1/16"
    • • Tweeter Height (mm) : 26.6mm
    • • Woofer Mounting Diameter (in) : 5-7/16"
    • • Woofer Mounting Diameter (mm) : 138mm
    ________________________________________________________
    These are the PIAA 2100 series driving lights. They have an Xtreme White bulb in them, and feature a 25 degree beam pattern. They are driving lights, NOT fog lights. They are used, and have a few small pitts in them, and a few scratches, but they are only minor cosmetic issues. I'll be more than happy to let you inspect them before you commit to buying.
    They're in perfect working order. I've just decided not to reinstall them because I don't have a suitable mounting position. They're bright as ****, and make a major difference in driving visability.
    Sale Includes:
    2 PIAA 2192 Driving Lights
    Wiring Harness with fuses
    PIAA switch
    [​IMG] [​IMG]
    _____________________________________________________________
    This is a 14 inch flat screen (not flat panel) Toshiba TV. It has four video inputs (2 composite, 1 s-video, 1 component), and a coaxial (cable tv) input. It is in extremely good condition, and has lived in my kitchen. I don't have a use for it in my new apartment configuration.
    Picture quality is superb. (I'll also throw in a lazy-susan turntable for an extra $5)
    -Brand new Clarion EQS746 7-band graphic equalizer/crossover. I purchased it to try to band-aid a small issue with my system, but realized that it wasn't going to cut it. The unit has been tested, but never installed. It still has the plastic protector sheet on the top.
    I don't have a pic of mine cuz my camera's dead, but here's a pic from Clarion's website:
    Here's info from clarion's website
    • 7-Band Graphic Equalizer
    • 6-Channel / 7 Volt RCA Outputs (Front/Rear/Subwoofer)
    • Adjustable Master Volume Level Control
    • Adjustable Subwoofer Level Control
    • 2-Channel RCA AUX Input with Adjustable Gain
    • Selectable 12dB Low-Pass Crossover (60Hz or 90Hz)
    • Gold Plated Terminals
    • Dimensions:7"(W) × 1"(H) × 4"(D)
  2. Dynapar
    hmm... i will talk to my buddy about the EQ. does it fit in a din slot?
  3. techy101
    yes, it's actually a half-din size.
  4. Dynapar
    it take it this is a powered unit that needs to be wired in? and it allows you to control F/R/Sub all wih the one unit?
  5. techy101
    Yeah, it's just like installing an amp, or anything else. It's got a nice little plug on it, that you connect +12, ACC, and Gnd to. It has one pair of L/R inputs. It has L/R sub outputs, Front L/R outputs, and Rear L/R outputs. It also has an L/R AUX INPUT, with an independent gain control. It also has a built in, adjustable crossover.
  6. Shane86
    Shane86 Well-Known Member
    What dimensions are the speakers?
    5.25" or 6.5"?
  7. techy101
    they're 6.5"
  8. TSTRBOY2004
    does the tv work normal.. ie picks up normal channels??? if so I may be very interested...
  9. techy101
    It's just a normal tv. it doesn't have an antenna on it (although I have one that I'd toss in for $15). But it works totally normal. Just hook it into your cable TV and off you go.
  10. Dynapar
    sorry friend isnt interested in the EQ right now. he is happy with how his apline deck is handling his subs. and thinks that $$ towards better speakers would be the route to go.
    what kinda tranny mods we talkin bout here?
  11. techy101
    Rebuilt torque converter, and Valvebody.
  12. techy101
    PRICE REDUCTION!!!!!!!!!!!!!!!!!!!!!!!!!!!!
    Come on, someone's gotta want these things!
    Esp. the lights, anyone who drove infront of me on the way up to the first ice event can vouch that they're bright as ****, and not the cheap walmart wannabe lights.
  13. techy101
    Tv Sold
  14. techy101
    BUMPage
  15. techy101
    *to the tune of frosty the snow man*
    Bumpity Bump Bump, Bumpity Bump Bump.
